Hey does anyone know the part numbers or where I could get the oem fender flares that come on the lariat? At least what I have seen.. I have a 2018 platinum and would like to get the oem flares.
Look into Bushwacker OE flares. I was told the Factory Ford flares require extensive drilling and modifications to install on a Non flare Fender and Bed Sides.
I bought a set of OEM flares from a member here that went bigger. They are designed for a fender with a bunch of holes in the side, but I’m confident I can make them work. Will try to remember to post back when I get them on...
I had the street style bushwhackers on my Toyota pickup a few years back, painted to match. They are a descent option. They bolt from inside the wheel well under the lip so no drilling in the side of the fender required. They rely on a bit of flex in the flare to keep them tight against the fender side, and are prone to rubbing the fender unless you use black round hose (often supplied with) to buffer the plastic edge from the fender. I wasn’t wild about the black tube, hence my plan to attempt OEM this time around.
I put the Bushwhacker OE flares on my 2019 and I like the way they look. I was worried about the flare rubbing the paint off along the edge so I had the area behind the flare sprayed with Line-X.
I tried to send you a message but looks like you can not get messages. I still have them and can ship them in original boxes.
I didn’t know if you could send a message or not I tired to message you a few times before I posted and i guess I can’t yet. Can you post a picture? What are you asking for them?
