Grille guard help
Old Sep 8, 2018 | 06:26 AM
VitovH's Avatar
VitovH
Grille guard help
Need some help in locating where the brace bars go through the radiator core support.
This is on a two wheel drive 1966 F100.
Thanks
Vito
Old Sep 8, 2018 | 08:58 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Vito - check out this thread at the link below. It shows the radiator support and the crude hole they cut in it and also shows the hole on the frame where one of the supports was attached and ND has also included the drawing from the MPC, too. It's about the best thread that I've seen on the factory grille guard mounting supports.
https://www.ford-trucks.com/forums/1...ush-guard.html
Chad
Old Sep 8, 2018 | 09:10 AM
TA455HO's Avatar
TA455HO
Lead Gopher
OK, that "crude" hole looks like it is some rubber seal which may just be somewhat torn in that one picture, too. Here's the two pieces that attach to the core support
C5TZ-8B239-A - Grille Guard Seal
C5TZ-8B240-A - Grille Guard Brace Seal Retainer
I couldn't find any of those parts available NOS.
I hope that helps some.
Chad
Old Sep 8, 2018 | 09:49 AM
6t6merc's Avatar
6t6merc
Vito, it sounds like you have the grille guard and parts and you're ready to start cutting. When i sold mine, complete with the seals, retainers and everything else, I included a paper template indicating the hole sizes and locations, made when the rad support was out. I think you're going to need to get precise measurements from an assembled truck with the guard. There might be someone here who can do this for you. IIRC the buyer of mine cut the holes from the back side and installed all the pieces without removing the grille. Way easier if the rad support is out though.
Eric
Old Sep 8, 2018 | 10:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Grille guard help
Upper pic (click on it twice to enlarge it):
Old Sep 8, 2018 | 10:54 AM
ridealong34's Avatar
ridealong34
Here's a frontal shot from a 65 I painted a few years back.
Old Sep 8, 2018 | 02:53 PM
VitovH's Avatar
VitovH
Chad
Thanks for the info Chad.
Old Sep 8, 2018 | 05:10 PM
VitovH's Avatar
VitovH
Eric
Thanks Eric
Vito
Shadowrider123
Jan 15, 2015 11:30 AM
68ranger704
Ford Truck Parts for Sale
May 12, 2011 03:42 PM
minkbigbird
Oct 19, 2010 07:47 AM
our83
Sep 11, 2010 10:33 PM
dlmoore
Sep 16, 2006 08:40 PM
