Headers
Old Sep 8, 2018 | 02:37 AM
PIGGYONAHOG's Avatar
PIGGYONAHOG
Headers
I got a 49 F1 with a 350SBC on a TH400 auto The truck has a Plymouth volare front clip and a Ididit adjustable column. The problem i got is the very tight space between the block and the steering shaft. on the left side.I got a set of ram horns with 2'5inch collectors and when under torque with the steering to the right the flanges on the collector catch on the UJ joint of the steering shaft. I have tried SBC tight hugger headers and they dont fit, The only thing I know fit for sure are ram horns with 2" collectors but these strangle the motor. What are people using with this set up. ??? Thanks
Old Sep 8, 2018 | 06:22 AM
Guntown's Avatar
Guntown
What type of Engine Mount are you running? Going to a solid motor mounts would stop any type of motor movement and should solve your torque lean. Or install a turnbuckle between motor and frame to stop the flex too. Other than that doing away with the flange and welding a 2.5 stainless pipe to the manifold, but with your torque lean I dont know how long that would last.
Old Sep 8, 2018 | 06:29 AM
jniolon's Avatar
jniolon
old and in the way
is your engine offset toward the passenger side at all?? that's about the only way to cure it... it's a bunch of work now to move the engine and transmission, but it will get you around that big ole honkin steering box
with a 460/volare set up in a 53 I had to offset 2" with a set of Sanderson headers... then I had problems with the right side control arms... scrapped it all and went Mustang II
john
Old Sep 8, 2018 | 05:01 PM
burnettd01's Avatar
burnettd01
Steering
Here is my steering - 51 f1 - 350/350 trans - Sanderson headers for C-10 Chev truck - Jag IFS. Engine shifted 3/4 inch to the passenger's side.
May give you ideas.
Dan
Gwilkrrs
Dec 12, 2017 11:28 AM
schoo
Aug 24, 2015 11:49 PM
Gicknordon
Jan 8, 2013 05:17 PM
Jeff55F100
Jul 6, 2006 09:07 PM
av8ford
Oct 5, 2005 09:36 PM
