Sponsored by: Real Truck
ball joint press info needed
Old Sep 7, 2018 | 03:15 PM
RAYJAY!'s Avatar
RAYJAY!
hi all going to buy a ball joint press, to do my 2010 f250 Super Duty what is every one using ??
Old Sep 7, 2018 | 07:43 PM
Djosbun's Avatar
Djosbun
I have the Astro Pneumatic set, as well as their secondary kit. I have used it for quite a few years on numerous cars. I bought the secondary set after buying my Super Duty, since the kit has the additional cup sizes that are used for the SD. I haven’t had to replace mine yet (F350) but for the cost the Astro set is a great value.
One tip I can give, to keep the kit lasting a long time, is to grease the threaded rod on every use. Makes the threads stay damage-free.
— Dave
Old Sep 8, 2018 | 02:20 AM
RAYJAY!'s Avatar
RAYJAY!
— Dave
dave you have the 7865 kit and the 7868 kit then I was looking at the 7897 kit i think it a combination 7865 and the 7868
Old Sep 8, 2018 | 06:04 AM
SuperDutyScaler's Avatar
SuperDutyScaler
I use the one from Advanced Auto all the time designed for 4x4 trucks. It's always had the proper dies so far and has always worked
Old Sep 8, 2018 | 07:36 AM
Djosbun's Avatar
Djosbun
Correct, I have the 7865 and 7868 add-on kit. I went with Astro because I use their threadcert tool and once had a small issue with it (after many, many uses). Astro’s customer service was excellent and took care of me. Since then, I buy strictly from them.
— Dave
Old Sep 8, 2018 | 09:26 AM
speedfreak78's Avatar
speedfreak78
Personally, I wouldn't buy anything other than a OTC. My father's old OTC set was used in a shop for 20+ years repairing heavy equipment and is still as good as the day it was new. The C is thick forged steel and the threads are smooth. I wouldn't think twice about putting a 3/4 impact gun on it. I bent the C on one of those auto parts store rentals before because the was aluminum. Also, on the cheaper on,es the threads are usually rough cut and have a lot of resistance when put under a load. So basically look for a thick STEEL C and smooth threads.
Also, use a high pressure rated grease on the threads, it makes a big difference.
Old Sep 8, 2018 | 11:32 AM
RAYJAY!'s Avatar
RAYJAY!
— Dave
yes Dave I have spoke to astro about the kits there very responsive when you call, was impressed that there call center was USA based, I did order the 7879 kit from amazon was 120.00 for the kit
Old Sep 9, 2018 | 08:53 AM
Djosbun's Avatar
Djosbun
OTC makes superb tools. All my jaw pullers are OTC, plus lots of other goodies. I have an OTC slide hammer that has seen more action than what’s behind my zipper. A++ gear.
— Dave
Old Sep 9, 2018 | 08:54 AM
Djosbun's Avatar
Djosbun
Great choice! It’ll serve you well for the price you paid.
— Dave
Old Sep 9, 2018 | 08:32 PM
KC8QVO's Avatar
KC8QVO
When I was gearing up for my front end rebuild I bought a shop press. I would rather use that for ball joints if you can remove the assemblies. You can make sleeves from tubing. I have several. The thicker the wall the stronger it will be (thin - 3/32" or less - wall will deform easier, but you may still be able to get by with it). I used A36 steel, which is mild/soft steel. The sleeves you get with the ball joint presses are usually much stronger alloy or tool steel.
One of the tools I am planning to build at some point is the equivalent of a very small portable shop press powered with a bottle jack. This way I can get hydraulic power under the truck as opposed to needing to remove parts to place them on the shop press, unless that is easier.
If your ball joints are rust-welded in place I am not sure how well a screw style press is going to work. I had U-joins rust welded shut and with 20 tons on them they still took a hammer to rattle the rust weld loose and get them to move - and when they went they went with a bang.
Old Sep 10, 2018 | 09:10 AM
brian42's Avatar
brian42
Veteran: Navy
You roll the dice with the "loaner" tools. While a great deal they are like rental cars and get abused because people are not held responsible as long as all the pieces get back to the store.
The first time I did ball joints I used the loaner tool from my local auto parts store. Great idea but the one I needed had been overstressed so the "C" was more like an open mouth and it wouldn't fit properly to work.
If you plan on going this route I would recommend going to the store and looking at the kit before you plan on doing the work so you can make sure the kit is in good shape and will accomplish the task.
Luckily I had access to a 20 ton press to get the ball joints out/in of the knuckles. If I didn't have that I would take the knuckles to a shop and have them swap the ball joints.
Just my .02
Old Sep 10, 2018 | 02:21 PM
ligito's Avatar
ligito
Do you mean Acme threads?
Old Sep 10, 2018 | 07:47 PM
speedfreak78
I'm talking about the finish on the contact surfaces of the threads. If there's any roughness or tooling marks it can cause increased resistance the tighter it gets. If the surfaces are nice and smooth, they'll slide easier.
Old Sep 10, 2018 | 08:07 PM
SnowPlowDriver's Avatar
SnowPlowDriver
I picked up an OTC frame and screw at a garage sale for $1.Lucky me.
Old Apr 30, 2019 | 03:00 PM
beachcamperf250's Avatar
beachcamperf250
How did the 7897 kit work out? Trying to figure out if I want to get that or get the 7868 + 7865 kits.
