Need some help
Old Sep 7, 2018 | 11:58 AM
Silver54's Avatar
Silver54
Need some help
Hey fellas,
Trying to find part numbers for bearings and seals for the ford 9" rear end I have. Its challenging as the auto parts people want me to know the year and model of the vehicle it came out of and that info is no longer available.
What I know currently,
Ford 9" rear,
Old style Big Bearing,
28 Spline axle,
What I'm guessing,
Think it came out of a late 1960's (67-72) F100
Any one installed new axle bearings and seals into one of these rear ends and still have Part numbers handy? If so I would greatly appreciate the help. I would like to get it put back together so I can mount it and clean up part of my shed.
Thanks in advance every one .
Old Sep 7, 2018 | 03:48 PM
carnut122's Avatar
carnut122
Probably a dumb question, but does it still have the ID tag on it?
Old Sep 7, 2018 | 04:02 PM
Smitty49's Avatar
Smitty49
If it hasn't got a Tag on the rear housing, I would pull one axle and look for the numbers on the bearings, races and seal!
Old Sep 7, 2018 | 04:39 PM
F1 coyote's Avatar
F1 coyote
measure axle diameter and inside housing diameter that should get you close.
Old Sep 7, 2018 | 05:59 PM
seaves46's Avatar
seaves46
Look closely at the ones being removed and you should see numbers marked on them .
All bearings and seals are marked with part numbers .
Old Sep 7, 2018 | 08:18 PM
Silver54's Avatar
Silver54
Tonight after some intense cleaning was finally able to reveal a pn on the bearings, F-208A-KK. Everything is is worn off, corroded or disintegrated.
Should hopefully be enough for me to finally get the proper kit.
Old Sep 7, 2018 | 10:06 PM
ben73058's Avatar
ben73058
Hey Jason,
I see another mode of transportation in your signature. What's the story
behind the helicopter?
Ben in Austin
1950 F1
Old Sep 7, 2018 | 11:04 PM
mtflat's Avatar
mtflat
It sounds like you found what you need. Your description sounds like the rear I have in my 48. Just tell them it for a 64 F100 - they won't know the difference.
Take the old seal with you to compare side by side.
Also, find a better parts store. One where they can id things without the computer.
Old Sep 8, 2018 | 01:22 PM
Silver54's Avatar
Silver54
Thanks MT,
Ben the helicopter in that picture was a couple years back when we did a bunch of seismic work in Florence Arizona. Up until just recently I worked as a Aviation Maintenance Engineer, (the equivalent of a type certified A&P in the US.) I no longer work for that company as I was offered a position closer to home as a Director of Maintenance. So now I do more office work that repairing helicopters. Still a good challenge though.
trucksRawsome
Dec 11, 2021 12:06 PM
Rollingscrapmetal
Sep 14, 2018 07:26 PM
Corkwheats
Feb 12, 2015 06:01 AM
JameyZ28
Jul 24, 2008 10:44 AM
1979ford
Dec 15, 2005 10:49 PM
