I order the correct ecm off of oreilly and keep having the same problem with the pins, i keep getting a 50 pin ecm and im missing the throttle return pin 47 on everyone ecm i get.
im got one more ecm thats for 88 with a 5speed coming in tomorrow. Im hoping it has the pin i need but if it doesn't do you know where i could find a ecm that will line right up or should i cut my losses and go carb?
1986 Engine Computer
Ford Truck F150Electronic Control Module, 8-302 (5.0L), AT, AOD transmission, Federal, 4x2-105KA18A035$45Arkansas Auto Recycling USA-AR(North-Little Rock) 1-501-945-2886
Ford Truck F150B4152$35Payless Auto Salvage USA-AR(Rogers) 1-888-383-2002
BUY ONE OF THESE...........
thanks thats probably what im going to do, these reman computers from cardone are ****. Everyone i have got is either damaged or not the correct one.
Idk why they left out the throttle return pins but there not worth $150 for the last few i bought.
i got one yesterday and put it on and my injectors were stuck spraying and i ran the numbers back and they sold me a 3.9 Lincoln i think computer and after that im not buying a reman ecm again.
I think im on my 13th cardone ecm now and from experience they are garbage lol
im going to buy a orginal tommorrow and hopefully it solves my problem
