66 hood weight
Old Sep 3, 2018 | 06:59 PM
jackpot's Avatar
jackpot
66 hood weight
Can anyone give me the weight of my 1966 F100 hood, less the hinges. Or, how many guys needed to safely remove
hood from truck, as I need to send hinges out for rebuild. Thanks, how about it anyone.
Old Sep 3, 2018 | 07:45 PM
ssandirene's Avatar
ssandirene
Two guys can handle it
i don't know the weight,but it's not much
Old Sep 3, 2018 | 08:03 PM
The Masked Rider's Avatar
The Masked Rider
A friend of mine had his rebuilt, he may chime in on a good place to have them rebuilt. Don't know your location.
Old Sep 3, 2018 | 09:42 PM
wyrm73's Avatar
wyrm73
I have two hoods floating around my garage currently. Seems like everywhere I put them, they are back in the way. They are awkward, but not so heavy. I move them by myself. No more than 50 pounds max. Taking it off the truck however, probably should be done with two people. It would be really hard to hold it stable with one hand and work the wrench with the other and risk damaging the hood or something else when it slips... not if...when.
Old Sep 4, 2018 | 07:57 AM
resonateur's Avatar
resonateur
It sure is convenient to have that third tall guy in the middle to support the nose of the hood. It makes it much easier for the other two to align bolt holes and make adjustments without having to support that cantilever effect of the hood. There is only one guy that I found that can rebuild the hinges as original, machining the pins and compressing them to look and operate correctly. It will cost you considerably more than a new set of imported hinges, though, if you want to go that route.
Old Sep 4, 2018 | 08:01 PM
Claybreaker144's Avatar
Claybreaker144
There's a guy near Lynchburg VA who has good reviews that charges 259 ea with no finish. He said the ford truck hinges were the most time consuming hinge he works on. He had my hinges for 6 months and couldn't tell me when he could get to them so I had him ship them back to me.
Old Sep 4, 2018 | 08:50 PM
resonateur's Avatar
resonateur
Wilson Antique Car Parts, Forest, VA. HoodHingeRepair.com. When mine were done it was about $225.00 each, but that was in 2015. Maybe things have changed with regard to service, but I got them back after a while...I don’t recall it being an inordinate amount if time. I didn’t care anyway, as I was in the restoration process and probably didn’t need them for two years! The important thing...absolutely no play in the hinges and the hood stays open in any position. He mills and fits each rivet for proper interference and to my knowledge, no one else makes these rivets or has the tool to set them as factory did.
Old Sep 4, 2018 | 09:15 PM
mountain dewd's Avatar
mountain dewd
I use my head (literally) when removing, installing and adjusting hoods.
Old Sep 4, 2018 | 09:34 PM
resonateur's Avatar
resonateur
Yea...I used to do that also. Then I started using my head really...and got an extra pair of hands to avoid mishaps.
Old Sep 4, 2018 | 10:45 PM
sawmaned's Avatar
sawmaned
i have a very good used set,that have not been in use for 30 yrs,if interested,
Old Sep 6, 2018 | 10:59 AM
Amish65F100's Avatar
Amish65F100
When I took my hood off it wasn't too heavy and I had my buddy help me lift it off once unbolted.
For me the hardest part was putting it back on. Where the hinge bolts up to the hood and within the hood itself is a steel bar with two bolt holes in it. Mine were loose within the hood so getting it lined up for the bolts was a real pain in the ***. I believe there should be something that secures those parts but my truck was missing them.
Old Sep 21, 2018 | 11:42 AM
jackpot's Avatar
jackpot
Jackpot here: I have been in touch with your guy and he tells me he no longer does 61 thru 66 hood hinges. He says they require to much time and they botch up his scheduling. I was very disappointed. Oh well so it goes in the restoration world.
Old Sep 26, 2018 | 01:27 PM
Murphy1966's Avatar
Murphy1966
2 people to take it off, 3 people to put it back on
Old Sep 26, 2018 | 01:36 PM
RattyFord's Avatar
RattyFord
I made my 4 and 7 year old do it. I wasn't feeling up to the task personally.
Old Sep 26, 2018 | 08:10 PM
resonateur's Avatar
resonateur
....so much easier the way Murphy said it...so why not do it the easy way?
