New owner 2000 Excursion V10
Old Sep 1, 2018 | 12:00 AM
palacios289's Avatar
palacios289
I finally joined the club. 2000 excursion limited v10 4x2. Only 109xxx miles. Trucks in great shape. Came with 4.30 LS rear end. This will be my tailgating vehicle to take the whole crew.
Old Sep 6, 2018 | 08:36 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Beautiful truck! Welcome to the club!
I originally wanted either Estate Green, Black, or Deep Wedgewood Blue, you saw how that turned out, lol
Old Sep 7, 2018 | 04:39 PM
manglass's Avatar
manglass
Your truck is almost identical to mine. You'll love it! I'm at 256,000 miles and counting.
Best of luck with it,
Lou Manglass
Old Sep 7, 2018 | 06:12 PM
wpnaes's Avatar
wpnaes
Welcome, you’ll be happy you joined our clan. Nice pic too. (how many FTE’rs get repped on their first post).
Old Sep 8, 2018 | 01:00 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by palacios289
I finally joined the club. 2000 excursion limited v10 4x2. Only 109xxx miles. ...
Great looking truck!
Couple of items -
1. Have the spark plugs ever been changed? The OEM plugs were Motorcraft AGSF22WM and the current replacement is SP-479. Check the torque on the plugs if they are OEM.
Ours had 104k with OEM plugs in it when we got it and blew #3 at 108k that had worked loose. Factory torque is 17 ft-lbs or so, most use 20-25 ft-lbs. When you change the plugs might as well throw on a set of Denso boots/springs, 671-0001, $30/10 on ebay.
2. Does it have a rear anti-roll bar? Handling will be much improved in turns and crosswinds after adding a rear bar.
3. If you plan to tow anything check the bottom radiator tank for the in-tank tans cooler. Early builds had that omitted.
4. Also, for towing the trailer hitch bolts were changed in later years which increases the hitch capacity rating.
5. If the shocks are original they are probably toast, ours were.
6. On ours a couple of tie rods ends were worn/loose, too.
Old Sep 9, 2018 | 11:01 PM
palacios289
Thanks. Plugs were done at 101k miles. Along with Monroe shocks all around. (Previous owner kept receipts). I just got a 30mm rear sway bar from the local boneyard and ordered new links from rock auto. Don’t know about the radiator having a cooling circuit for the trans fluid. I’ll take a look this weekend as I’m doing the 2005 facelift. Truck runs fine and front suspension has some play but it’s pretty good. I’ll probably end up doing ball joints, bushings and tie rods just to get it nice and right.
Old Sep 10, 2018 | 05:45 AM
WE3ZS's Avatar
WE3ZS
Nice EX!
A RWD V-10 with the 4.30 gears would make for a great tow rig.
93F250
May 10, 2016 01:12 AM
muj0
Aug 19, 2015 09:42 AM
motopsyko32
Vehicles for Sale
May 22, 2010 04:17 PM
PhoenixRisen
Vehicles for Sale
Mar 20, 2010 05:48 AM
ezriderrandy
Modular V10 (6.8l)
Sep 28, 2004 10:46 AM
