POWER SOURCE
Old Aug 31, 2018 | 07:05 PM
Fyrwlkr's Avatar
Fyrwlkr
POWER SOURCE
Installing a EFI system that needs a power source that's hot with the key on or in start position. the electrical system has been changed from original. Can't seem to find any circuit that fits the bill!
Old Aug 31, 2018 | 07:10 PM
seaves46's Avatar
seaves46
Surely there is somewhere on the back if the ignition switch that fits the bill .
Old Aug 31, 2018 | 07:22 PM
F1 coyote's Avatar
F1 coyote
look at the back of your ignition switch and follow the turn to the contact points to find your wires. you need constant hot on and with starter.
Old Sep 1, 2018 | 11:39 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
With all due respect, if that is causing you issues please seek help with your install. Those are some expensive parts that you do not want to ruin.
Old Sep 1, 2018 | 02:16 PM
BlueOvalRage's Avatar
BlueOvalRage
Tapping ANY existing circuit for an engine management system really isn't a good plan. I would feed your EFI system directly from the battery through a relay. You can use a feed from the ignition "ON" terminal of the relay to close the relay.
Jadgarul
Apr 3, 2012 10:47 AM
mattbleakley
Nov 15, 2010 02:53 AM
Benaghetto
1983 - 2012 Ranger & B-Series
Feb 16, 2008 04:58 PM
masonmachines
Jun 15, 2004 09:37 PM
