ok everyone I have a 1985 f25o with a 351w the truck will fire up and stay running as long as I’m supplying it with fuel either spray starting fluid or by using the throttle? Could my fuel pump be bad or what? Any and all help appreciated.
If it stays running with you giving throttle then its not a fuel pump issue its a carb issue. might have dirty jets or maybe even a dirty fuel filter. Possibly even a dirty air filter but I assume you tried running it without the airfilter assembly.
If this suddenly happened recently it's possible that your truck dieseled after shutting off and it coughed out a vacuum cap.
Ok so if it does stay running with throttle then as said not the fuel pump or filters, air or gas.
If bed pump then would not run with throttle, same with a bad fuel filter because of no fuel to carb.
Bad and it would have to be REALLY BAD air filter it would run really rich (to much fuel) or not at all.
My guess even if it did not diesel (sneeze) is a vacuum plug fell off causing a big vacuum leak that cant be overcome at idle or idle jets in carb are plugged.
Let us know what you find.
Dave ----
Thanks Dave yeah I think sneeze is a better description.
this happened to me about six months ago. I could have easily and conveniently retrieved the rubber vacuum cap underneath the truck where I had shut it off but unfortunately I had driven off before I figured out what happened.
On mine there is a three or four inch "vacuum tree" and that is where it was missing.
