351M Stalling out when braking
Old Aug 28, 2018 | 01:49 PM
Jack Detwiler's Avatar
Jack Detwiler
I have a question for those with the knowledge. I have a '78 F150 Supercab with a 351M. The motor has been bored .30 over, ported and polished, has a performance intake manifold, and cam. The motor is running great, I do need to turn the idle down a little though. My issue that I am having is when I am driving and come to a stop or even slow down below 10-15MPH the motor stalls out. When I put the transmission in neutral and coast to a stop the engine wants to stall then too. I just drove from Saginaw, MI to Jacksonville, NC and it was a bit of a pain in the a$$ when I was pulling off for gas or having to stop for traffic. I am not sure where to start with trouble shooting this issue. I was thinking it could be too low of a stall on the stock converter but I don't think that would cause the motor to stall when I was rolling to a stop in neutral. I thank you in advance for a steer in the right direction.
Old Aug 28, 2018 | 05:01 PM
mrbigshot's Avatar
mrbigshot
the cam is too big for the torque converter. the bigger the higher your stall needs to be unless you set your idle to 1k rpm. once the converter is applying pressure its the same as having a clutch out on a manual.
Old Aug 28, 2018 | 06:58 PM
Blue and White's Avatar
Blue and White
Agree the converter is a potential cause. Some other areas to look are:
- Timing. The bigger cam will want more initial vacuum advance. Stock was typically 8-12 degrees. A bigger cam may work better with 15-20 degrees initial (vacuum advance disconnected and plugged. With this setting, you may have to modify the distributor so full mechanical advance does not exceed 34-26 degrees at higher RPM.
- Carb. A partially gunked up idle circuit or incorrect adjustment can cause this problem. Sometimes opening the butterflys to get a higher or even adequate idle speed with a low vacuum cam uncovers "running" ports and the idle suffers.
- Brake Booster. If it has an internal vacuum leak it could be letting excess air in when you press the brakes and leaning the mixture.
I hope the above helps.
Also, can you post cam specs?
Old Aug 29, 2018 | 10:10 AM
beartracks's Avatar
beartracks
Brake booster.
46Whizzer
Dec 24, 2015 10:27 PM
famouscoops
Jan 26, 2008 12:14 PM
robertbourque
Feb 25, 2007 11:29 AM
Ratsmoker
Feb 20, 2004 08:25 PM
craig429
Jan 6, 2002 03:44 AM
