Please answer this electrical question for me
Old Aug 27, 2018 | 01:38 PM
meck1's Avatar
meck1
For the 1997 Ranger, my Ford Electrical Manual shows the light blue/yellow wire (input from the PCM- 5V) at the clutch pedal position switch connected permanently to the gray/red wire (output to engine controls such as the IAT, TPS, ECT, etc.). On the manual transmission, the two wires are disconnected at the clutch pedal position switch when the clutch pedal is released. My question: on the manual transmission ones, if the two wires are disconnected/open circuit when the pedal is released, how do the ECT, IAT, TPS, etc. get the 5V reference from the PCM. I see no other way on this electrical circuit diagram. (I'm asking this because I'm trying to run down a short right now, and this is a point that I don't understand).
I will really appreciate it if someone can clear this up for me.
Old Aug 27, 2018 | 03:09 PM
projectSHO89's Avatar
projectSHO89
That circuit is an input TO the PCM, it is not an output. Therefore, the rest of you conjecture is incorrect.
The gray/red wire is the +5Vref power line that is an output FROM the PCM. The sensors are already connected connected to the +5Vref power line.
hdgapeach
Electrical Systems/Wiring
Jul 30, 2017 05:29 PM
f150thom
Mar 25, 2017 12:23 AM
ta2rob
Sep 6, 2011 12:56 AM
newowner1
May 28, 2007 09:25 AM
BinaryWhisper
Dec 22, 2005 11:23 AM
