Front spring ratings?
Old Aug 25, 2018 | 08:28 PM
Rtr2017!'s Avatar
Rtr2017!
19 F350 4x4 bought with a “camper package” . I’m wondering if there’s any way to decode the front springs?
Does this truck have 5200,5600, 6000lb rating? The part # is 5C34-5310-AEE. I’ve checked Ford parts, can’t find the “AEE”
Old Aug 25, 2018 | 08:56 PM
CopterPilot's Avatar
CopterPilot
I can tell you my truck is a 2017 F350 6.7 4x4 SRW with the camper package and it had 5600 lb springs. I believe there is a chart with all of the codes on it.
Is your truck diesel? Dually?
Old Aug 25, 2018 | 09:04 PM
skanj0's Avatar
skanj0
AE coils are 5,200lb. You must have a gasser, as a diesel with Camper package woukd have ADs (5,600s).
Old Aug 25, 2018 | 09:06 PM
xxxsherpa's Avatar
xxxsherpa
Doesn't it say on the white sticker on your door jam?
Old Aug 25, 2018 | 09:19 PM
h20camper's Avatar
h20camper
Yes, it does. My 6.2 with camper and plow packages has 5600 (DD).
Old Aug 25, 2018 | 09:31 PM
Rtr2017!'s Avatar
Rtr2017!
Sorry.... yes truck is gasser SRW. I’d read where the spring rate with camper package would be “one higher” than computer selected as result of options chosen” , or wording similar to that.
The GAWR Front says 5200 on sticker. Im learning from you guys, guess that means the spring rates?
I’m assuming that the standard spring for F350 must be #4800?
Old Aug 25, 2018 | 09:34 PM
skanj0's Avatar
skanj0
Correct. Ford Super Duty Front GAWR = coil spring rate.
And yes, the standard front coil spring rating for a 4x4 SRW gasser is 4,800 lbs.
Old Aug 25, 2018 | 09:43 PM
wfedwar's Avatar
wfedwar
This might be a fine point, but spring rate is given in force/distance, such as lbs/in. How much force is required to compress a spring a certain distance. The numbers described here are GAWR, or the weight the axle is rated to carry. There is usually a relationship between spring rate and axle rating, but that doesn’t have to be the case.
Old Aug 26, 2018 | 09:59 PM
skanj0's Avatar
skanj0
Ford seems to dumb it down for people and it lists the gross FAWR the same as the coil spring rate. So if your truck comes with 4,800 lb front coils, your FAWR will be listed as 4,800 lbs. If your truck comes with 6,000 lb coils your FAWR will be listed as 6,000 lbs.
I recall Dana/Spicer rates the front Dana 60 in 2005+ Super Duty’s at 6,500 lbs max capacity (FAWR), and Ford offers it with a max capacity coil spring of 6,000 lbs.
Old Aug 27, 2018 | 08:56 AM
tfalk's Avatar
tfalk
Strange looking at some of these combinations... my gas 18 F350 CCLB with the plow package, no camper package, has the 5990 front GAWR.
Old Aug 27, 2018 | 11:49 AM
toymaster's Avatar
toymaster
^^^^ For the '18MY they changed the 6,000 to #5,090 I did not read anything that tried to explain the difference. I found my self wondering why even bother with a 10lb difference in the paper work. In the real world, in this context, 1/10 of a percent does not matter.
powellbj
Jan 6, 2017 07:10 PM
smlford
Oct 12, 2014 03:43 PM
new camper
Dec 4, 2011 08:04 AM
rayezra
Sep 15, 2009 07:39 AM
ehms
May 30, 2005 03:53 PM
