Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F700 Project - HELP
Old Aug 25, 2018 | 02:56 PM
AxCrooked's Avatar
AxCrooked
F700 Project - HELP
Hello!
This is my first post to the forums! I hope I'm in the right area, if not let me know and I can move it.
Anyways, I've recently purchased what I assume to be a 1963 Ford F700 on a whim and have no idea what it really is and where to start!
I've already got the truck running and it looks like a Y-block but I'm not familiar with them, or anything on this truck for that fact.
The truck is a 4-speed with granny gear and a 2-speed rear. The frame stamped VIN is listed as F70IU371398, but I am missing the door tag
I'm interested to see what anyone has for information about power-brakes / disc-brake conversions and for the listed VIN ....
Any help is appreciated! Thank you!!
--Ethan
Old Aug 25, 2018 | 05:01 PM
third66go's Avatar
third66go
Welcome! - you are not alone with whimsical big Ford trucks...
F70IU371398
F70 F700 series
I 302 gas V-8 4V 163 HP @ 3600 rpm rated power
U Louisville Assembly Plant
311398 January 1963 build date
Just guessing, but that big round thing under the LH running board might be a brake booster - others in the know will confirm?
Forel Publishing (among others) have digital parts books that are extremely helpful - even the free demo segments on-line are enough to get you going sometimes.
Cheers
Old Aug 25, 2018 | 07:06 PM
85e150's Avatar
85e150
Welcome to FTE!
A combination of good news, bad news:
Good, you have Dayton style wheels, which will allow a conversion to tubeless (if not done already) and they aren't widow makers.
Bad: 302 Y Block, a Lincoln Y Block--Parts can be found at the corner of Slim and None.
Good: you do have "power brakes" as the "big round thing" under the driver seat is your hydro-vac booster. These are made by Bendix and other brands, and are found in every medium truck from the late '40s (maybe earlier) until the '70s or '80s or later. Rebuild kits and rebuilt units are available.
Bad: Brake drums are not available new, and are a salvage yard item. (see "302 parts)
Good: Other brake parts are available through NAPA and other suppliers.
Bad: There are no disc brake conversions in medium trucks. You find a disc brake equipped axle of the appropriate weight rating off a later truck and swap axles.
Good: the combination of power and gearing does not require disc brakes, although balance that out with the pucker factor if hauling heavy in hill country.
Since you bought it on a whim are you going to run it as a worker or convert it to some other use?
Old Aug 25, 2018 | 09:55 PM
AxCrooked's Avatar
AxCrooked
Thank you both for the information and quick responses!
Most of the information is enlightening to hear and some not so great...!
Honestly, I bought the truck to play with so I wouldn't break my car during school season, but I am leaning towards an engine/trans swap and brake upgrades(I live in the hills/mountains of my area).
Once completed the truck would be used more for weekends rather than a workhorse...
--Ethan
Old Sep 7, 2018 | 04:24 PM
Roger Walling's Avatar
Roger Walling
If your brake booster in a "hydro vac" you should put a charcoal filter on the vacuum line as the gas fumes will get to the rubber diaphragm and cause it to fail.
If it has failed, do not rebuild it. buy a new later year one as the rebuild parts use old OEM parts and they only last a year.
I went thru two before I bought a new one.
I bought mine from,
Midwest Power Products.
1 815 942 0550
$445. Part # 374980N
Old Sep 9, 2018 | 03:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1957/63 Ford Truck Parts Catalog available on a C/D from hipoparts.com
F350moneypit
Feb 28, 2017 08:43 PM
BlackMomba
Dec 30, 2015 11:38 AM
Pennypincher
1947 and Older Ford Trucks
Nov 16, 2011 07:30 PM
John - NNY
Jul 5, 2009 05:29 PM
dads truck
Sep 17, 2004 06:58 AM
