302 Rear main seal
Old Sep 23, 2003 | 05:26 PM
Coupe_Devil's Avatar
Coupe_Devil
Unhappy 302 Rear main seal
Anyone have an idea on how to swap a rear main on a 302 in a 1988 ford f-150 with out pulling the motor?
Old Sep 23, 2003 | 07:13 PM
jwtaylor's Avatar
jwtaylor
302 Rear main seal
You have to slide the tranny back after you properly secure the vehicle then punch two opposing spots on the seal then screw two machine screws into the punched holes and pull it out. then lube the new seal with oil and put it on. Sounds simple it is simple but it is also a pain in the butt. Good luck
Old Sep 30, 2003 | 10:08 AM
R8R MAN's Avatar
R8R MAN
Thumbs up rear main seal
I agree with the previous post. I used the old seal a driver and a block of wood to seat the seal. May as well change the oil pan gasket. Use the one piece gasket and fish it under the oil pick up. Good luck!
