"Turning up" a diesel
Theres everything from replacing the injectors with larger injectors, to chips, microtuners, intake/exhaust, propane ...
Injectors are a pretty spendy venture, most will make the truck breathe better (intake, downpipe, exhaust) and then go with a chip/microtuner for added horsepower/torque
My guess would be that they are talking about fuel pressure. I hear this alot too, but mostly from Dodge Cummins owners. From what I understand, it is very easy to "turn up" the fuel pressure on a Cummins. I've never done it, never seen it done, so it may be BS.
While we're on the subject, a friend of mine did a $3 mod to his '01 F-250 that increased the fuel pressure. According to him, 2 pieces of wire and a switch was all he used. This loop bypasses a resistance point, so when the switch in "on", fuel pressure is increased (by how much I have no idea). When it's "off", everything is back to stock. He has no idea how to do it on my '02, alot of the wiring is different. Anyone know anything about this?
On a Cummins 12v, turning up the pump is easy, you just slide the fuel plate in the injector pump forward. My old company truck was a 98 Dodge. I slotted the slots in the fuel plate more so you could slide it more. It makes a big difference. Kinda like free power. The 12v Cummins is all mechanical injection, No computers, the 24v has a computer. All 98.5 & up are 24v.
Yeah, most of what I've heard was from Dodge guys. One guy who went to Wyoming tech diesel school even said something about putting a nickel in the fuel pump to gain a significant amount of power. I knew even less about diesels then than I do now, so I just kinda shook my head and nodded. Now that I think about it, it doesn't really make sense.
The nickle thing I cannot see how that would work. I have learned alot about the 12v cummins engine during the time I drove and worked on one (glad I have my powerstroke now). The injector pump pressure lever is controlled by the fuel plate. The fuel plate has a shape that maps fuel vs. rpm. There is another part that controls low boost fueling.
Enough about Cummins..
Jason
Jason
Re: "Turning up" a diesel
Look at the post in this forum about 97 intercooler, I posted a link to a website with a good step-by-step on how to do the install. You'll have to take everything off the front end and cut holes for the intercooler tubes, weld on some mounts, then either buy or make pipes that clear everything. A weekend job if you have all the right tools. Read the other post and check out the website, pretty good article.
Re: Re: "Turning up" a diesel
Originally posted by JMorton
You're refering to the 10k resistor instaled on the ICP sensor, gives you a little more power and for me, about 1MPG increase. real easy to do.
10K MOD
It's realy simple, just go to Radio Shack and buy a 5 pack of 10k-ohm resistors for $1. take one out and get a 5 inch piece of 22 gauge wire and cut it in half, strip about and inch from one end of each and about 3/4 inch from the other ends. solder the resistor to the 3/4 ends, one piece of wire on each side of the resistor. cover in shrink tube and heat so it looks like one wire. Take 3-4 strands of the wires from the stripped ends that are left and twist together, cut off remaining strands so you have a real thin piece of wire. Remove the connector from the ICP sensor, this is the sensor at the front of the Driver's side cylinder head. when you look at the connector, it will look like two eyes and a mouth. insert one bare wire into the mouth and one into the right eye AS YOU'RE LOOKING AT THE CONECTOR!! Bend the wires around and make sure they don't touch eachother. re-connect the harness to the sensor and make sure it snaps into place or it will set a check engine light. Start the truck and take it for a ride. Lower resistance resistors is supposed to help the power gains but will give a rougher idle. Give it a try and see what you think!!
