Sterling 10.25 question
Old Aug 24, 2018 | 11:16 AM
Paul Nanna's Avatar
Paul Nanna
I picked up a 1990 Sterling 10.25, 3.55 claimer from the neighborhood to replace the Dana 60 with a 4.10 rear axle.
This will go under an old 1952 Ford bread truck that's been outfitted with a 2V 400 Magnum with C6.
Everything looked good and there are no leaks or seepage. The pinion yoke fits tight with no slop but.....
When the pinion seal was pulled to check the front bearing, as I was wiping the race down and looking inside i found a hole.
Yes a hole at about 8 o'clock in the casting running under the bearing race.
Took a picture and shared with a co-worker who builds 4 wheel monsters and engines as a hobby.
His thought was that it is a method to get lube into the front bearing and not a problem. It was his "theory" admit-ably and
so I am credulous and wonder if I have to scrap the axle and call it a day.
Sterling hole in casing.
The hole is kind of ragged and not "finished"at all, taking up about an inch run along the underside of the bearing race.
I will pop the rear end off the pumpkin this weekend and look for steel gravel.
Thanks.
Old Aug 25, 2018 | 05:28 PM
Paul Nanna's Avatar
Paul Nanna
No gravel... the inside is clean.
Have seen some weird casting stuff in the past... unfinished looking anomalies.
Am I just being naive?
Old Aug 27, 2018 | 09:50 PM
jk080's Avatar
jk080
Transmission Rebuilder
It's not uncommon to have a oil passage to channel oil under a bearing race, it looks like its cast like that to me.
I would use it.
finneys98xj
Apr 28, 2011 09:04 AM
sckootter16
Feb 14, 2011 05:36 PM
cujo8
Dec 17, 2006 08:41 PM
AK F150
Dec 28, 2002 01:43 PM
DrFord
Aug 27, 2002 11:45 PM
