6.2L V8 Discuss the 6.2L V8
Larger fuel tank for the 6.2 trucks
Old 08-22-2018, 03:58 PM
FastTaurusSHO's Avatar
FastTaurusSHO
FastTaurusSHO is offline
I got to thinking, how many people would upgrade the fuel tank if it was available? Perhaps I've got long bed envy, but that 48 gallon tank range sure would be nice when towing.
Sure seems to me that a titan diesel tank would work, after all, the plastic tank it self shouldn't care if it is holding diesel or Gasoline, but the venting, fuel pump, etc is likely where the difference lies. Anyone know more or done more research on this? I know nobody offers a larger replacement tank and probably never will.
Old 08-22-2018, 06:27 PM
stein4's Avatar
stein4
stein4 is offline
I would definitely upgrade to a larger tank.
Old 08-23-2018, 09:37 PM
Barney1234's Avatar
Barney1234
Barney1234 is offline
I definitely would! Contemplated the cclb for the larger tank, but it's too damn long and a pain to maneuver in a parking lot. Sure wish that Ford would fix this.
Old 08-23-2018, 10:14 PM
Squisher's Avatar
Squisher
Squisher is offline
My wife says the same thing about the longbox.
Old 08-24-2018, 09:47 AM
dnewton3's Avatar
dnewton3
dnewton3 is offline
I would, and will, if it's possible.
My buddy just ordered a 2019 CCLB 6.2L. His will come with the factory 48 gal tank. (this is the only reason he ordered a truck; he wanted an F250 CCLB (with 4.30 gears) for the big tank; those are not common on lots).
My 2018 SCLB has the 36 gal tank. I bought off the lot.
I can assure you that when his gets delivered, I will be underneath both his and mine, taking notes and measurements.
First it has to be able to physically fit in the location to doable for reasonable effort. Then I will have to assess if there are other issues:
Are the connections same?
Are the hose locations and lengths the same or at least similar?
Are there vent location issues?
Are there fill hose issues?
Are there control module issues? (like do I have to reprogram the "capacity" in the computer so it knows when full is full and empty is empty?) This is my greatest concern; I don't have ForScan and I'm not good with computer programming, etc.
Unforeseen issues?
If I can make it work, I will go for it. But it has to be doable from a DIY garage perspective.
Old 08-25-2018, 02:59 PM
brickman's Avatar
brickman
brickman is offline
Get a long box and install one of these and it’s dot approved for gasoline.Refueling Tank and Toolbox Combos
Old 08-27-2018, 06:34 AM
dnewton3's Avatar
dnewton3
dnewton3 is offline
Not really conducive to getting my Victory in the back ...
Old 08-27-2018, 09:36 AM
RandyinTN's Avatar
RandyinTN
RandyinTN is offline
Old 08-27-2018, 09:40 AM
DESERT ED's Avatar
DESERT ED
DESERT ED is offline
I was crawling around under my 14 short box and noticed there's definitely some room by the tank, could realistically add another 3-5 gallon capacity. I think my tank is 26 gallons.
Old 08-28-2018, 05:41 AM
dnewton3's Avatar
dnewton3
dnewton3 is offline
Old 08-29-2018, 08:24 AM
JKru's Avatar
JKru
JKru is offline
There is no fuel tank in the world worth $1,500. Not even if it was 24k gold plated....
Old 08-31-2018, 09:20 PM
acadianbob's Avatar
acadianbob
acadianbob is offline
Yep!! .........Agree with that . . . . .
I bought a Type II gas can (5 gallons) and cable it in the box . . . $85 Have never needed to use it . . . .
Old 09-02-2018, 08:57 PM
yesmars's Avatar
yesmars
yesmars is offline
4wd Low
its funny I have a 62. long bed 48 gallon tank and the range is nice for long trips but around town I find myself not wanting it to get below half a tank. Most pumps in my area will not allow more that $100 per card swipe, and I hate standing there for 20 waiting for it fill up. for sure it is nice on trips, I was on a trip the other day and stopped and filled up on the way home and it showed 667 to empty after the fill up. Usually around town after a fill up it will show around 550 to empty.
Old 09-03-2018, 07:12 AM
Screamingbear's Avatar
Screamingbear
Screamingbear is offline
No fit
Unforeseen issues?
I
I have a CCLB.
The 48 gallon tank extends a LONG way under the cab, and it tightly conforms to the available space.
There is no chance you can hang it under another cab configuration.
Old 09-04-2018, 07:37 AM
dnewton3's Avatar
dnewton3
dnewton3 is offline
Originally Posted by Screamingbear
I
I have a CCLB.
any chance you can measure the distance front-to-rear of the tank you have? (how "long" is your tank front to back?)
my truck has about 22" of free space ahead of the tank; that's a lot of empty real estate.
Quick Reply: Larger fuel tank for the 6.2 trucks
