Carb jet recommendations
Old Aug 28, 2018 | 12:01 AM
baddad457's Avatar
baddad457
If I recall the 80457 was the Ford version of the 600. It was listed for everything from 302 to 390. So jetting could have covered a wider range in numbers. I know a 390 will pull more vacuum with it than a 302 would, so jetting would be different.
Old Aug 28, 2018 | 05:09 AM
The Masked Rider's Avatar
The Masked Rider
Not sure if this link will work. Only know if I post it.
http://documents.holley.com/techlibrary_carb_numerical_listing.pdf
If it comes up, go all the way down to 80457. It DOES show 69 mains BUT 80457-1 through 8 shows 64 as main jets. Interistin. SO the reason I asked what the date is on the carb. Maybe a re-jeting for smog carbs? No idea.
Secondary plates are all the same.
Old Aug 28, 2018 | 05:11 AM
The Masked Rider
Guess you might need to copy and paste the address.
Old Aug 28, 2018 | 11:43 AM
Destroked 450's Avatar
Destroked 450
My book is Holley's 1999 Performance Catalog, can't find my old 80's book.
My book only shows the original 80457 plus the -1 and -2 , doesn't show anything newer.
Looking at the newer 80457 shows they upsized to a 66 jet at some time.
Documents show they used 64 jets from -1 to -7, not sure what the latest version is.
Hadn't heard of the 80457 before but after some searching it appears to be an electric chock version of the old 1850 600cfm carbs I messed with years ago.
They would run on anything right out of the box but run better with the prober jetting for the size engine it was on.
Old Aug 28, 2018 | 06:03 PM
The Masked Rider
Yeah, wish that link would work by clicking on it.
if you copy and paste it, it goes right to the site page. Holley sure made a lot of different carbs.
AND who knows what has been done to them over the years.
I have a 083310-1 780 vac seconday setting top my 428. I myself have changed a few things. Replaced the secondary metering plate for jet block. 50 cc pump with a brown cam. I believe a 35 squirter, I think, also with the hollow screw to flow more fuel. Quick change secondary spring kit. I love that.
A friend of mine makes the jet blocks for the Holley where you can remove the jets from the top of the block. Pretty cool since you don't need to pull the carb apart. ALSO a pretty good price for them.​​​​​
Old Aug 28, 2018 | 06:22 PM
baddad457's Avatar
baddad457
I refitted an 1850 600 with dual feed bowls from a 750, then reworked the top by removing the choke assembly and casting then smoothed it all out with a die grinder.. Also had to make a reversed air cleaner bottom for my 3x2 setup to fit both an 89 Ranger and the 77 Comet it's in now to clear the cowling's on both vehicles.
Old Aug 28, 2018 | 06:41 PM
The Masked Rider
Haaa, I cut off the choke on one of mine like that. Ran great after ya got it started but still had to spray it to get it fired up. Sometimes pumping the crap out of it and closing the blades - making it think it had a choke. . You sure can move a lot of air with out the choke in the way.
Old Aug 28, 2018 | 07:26 PM
baddad457's Avatar
baddad457
Naw, just had to keep it tuned. Or run it with an EFI cam Never had trouble starting mine with electronic ignition and the F4TE or B303 roller cams.
Old Aug 28, 2018 | 10:56 PM
The Masked Rider
$$$$$$$$ can solve most all problems except dieing. Maybe next life.
Old Aug 29, 2018 | 12:11 PM
Destroked 450
I have a original Holley 4575 1050 Dominator that still has the choke horn and choke plates in it, most where shaved off back in the day.
Old Aug 29, 2018 | 02:35 PM
The Masked Rider
Thinking someday you'll use it.
Yeah, I look around and see 'sruff' I've had for years and ask myself WHY. Little by little, I have been weeding. I figure that if I do it slowly, it won't hurt.
Old Aug 29, 2018 | 05:33 PM
Destroked 450
Probably not, had plans for it years ago but now just hoping I can get the 406FE with 3x2's in my Fairlane before I get to old to drive it.
Old Aug 31, 2018 | 01:44 AM
  #28
83sd's Avatar
83sd
Thanks for the advise guys. Got it set back to stock thanks to you guys and the local performance parts store . Installed it tonight and hope to fire it off tomorrow .
bhain
18
Oct 15, 2018 12:37 PM
flipklos
Feb 6, 2009 01:18 AM
obey_your_master
Jun 1, 2008 11:14 PM
Alster
Mar 2, 2007 12:33 PM
scamardo
Dec 18, 2005 09:47 PM
