Bypassing the ignition switch
Old Aug 20, 2018 | 11:16 AM
hillcountryflt's Avatar
hillcountryflt
I brought home my parts truck yesterday and have not spent any time with it to speak of. However, I am seeing the ignition/key insert laying on the floor and the wiring under the the dash pretty messed up.
For the purpose of starting and running the engine, can you advise as to a simple way to bypass the ignition switch in the dash. I do have a a remote starter that might be useful.
Old Aug 20, 2018 | 11:21 AM
FuzzFace2's Avatar
FuzzFace2
Dose the solinoid on the fender well have a wire going to th I stud on it?
If so put power to it, short from battery +to the S stud using the starter switch and you should be good.
To stop just pull the wire off the I stud and motor will shut down.
Dave - - - -
Old Aug 20, 2018 | 12:01 PM
hillcountryflt
I recall when you use the solenoid for this, you need to have the ignition switch set to on, correct?
Old Aug 20, 2018 | 12:14 PM
FuzzFace2's Avatar
FuzzFace2
Only if you don't run a wire from battery + to the I stud of the solinoid that is the "hot wire" to power the ignition and why it is marked with an I.
Dave - - - -
Old Aug 21, 2018 | 12:26 AM
Thipdar's Avatar
Thipdar
If you would like to actually put the ignition switch and key back into service, let us know what year truck you're talking about.
Old Aug 21, 2018 | 07:09 AM
hillcountryflt
It's a beat-up 71 Ranger XLT.
I won't want to waste my spare factory cylinder on it.
Just want to make it where it is easy to crank while working on the engine.
Seen under the ignition switch is some of the hacked wiring.
Old Aug 21, 2018 | 09:59 AM
Thipdar's Avatar
Thipdar
In that case, I'd second what FuzzFace said
lakecityg
Electrical Systems/Wiring
Jul 4, 2011 08:24 AM
Woodsman_30350
Jun 6, 2011 12:27 PM
Gregory Glaser
Aug 18, 2007 03:08 PM
77Lance
Jul 15, 2004 03:10 PM
hugobernal22
1997 - 2003 F150
Mar 24, 2003 04:05 PM
