Brake Problems
Old Aug 19, 2018 | 08:59 PM
MatteoC's Avatar
MatteoC
Brake Problems
Hi guys,
I have a 1978 f-150 Custom.The truck sat for about 15 years, and was driven little to none at all during that time. I've got it back on the road, but the my brakes don't seem to have much stopping power at all. The brakes are working, but they don't lock up, even if I slam the pedal down as hard and far as it will go. Cant skid the tires. So far Ive replaced the booster, master cylinder, front calipers, rear drum cylinders, front brake pads, bled the lines and bench bled the master cylinder. I've also adjusted the push rod in the booster. Im running out of ideas. Haven't replaced the brake pressure differential valve, but my understanding is that this helps distribute even hydraulic pressure to the front and back brakes. Any feedback is much appreciated!
Old Aug 19, 2018 | 10:04 PM
flatbedfordguy's Avatar
flatbedfordguy
Adjust your rear shoes through the "adjustment slot" on the backing plate, move the shoes outward until you can hear them scrape on the drums while spinning the tires. You would be surprised how much pedal travel this excess slop can take up. it's like a new brake system after properly adjusted.
Old Aug 19, 2018 | 10:33 PM
Ozzie H.'s Avatar
Ozzie H.
Are the lines without restrictions? Many new brake systems are designed so as to NOT lock up the wheel. The designers think that produces a shorter stopping distance.
Old Aug 20, 2018 | 09:34 PM
MatteoC's Avatar
MatteoC
That helped a lot. And in the process, I noticed that the adjuster had somehow popped out of place. Something must have got messed up when I installed the new parts. Thanks so much for the feedback!
Old Aug 20, 2018 | 09:35 PM
MatteoC's Avatar
MatteoC
My issue has been resolved. Brakes are working fine now. Thanks for the feedback!
bkbauer1955
Feb 2, 2012 04:46 PM
corey892
Apr 4, 2008 10:20 PM
79f100six
Jul 5, 2007 01:48 AM
kenny236
Jan 30, 2007 07:10 PM
shortblock2000
Apr 8, 2005 12:14 PM
