Door Lock Issue
Old Aug 19, 2018 | 11:27 AM
hkushner7's Avatar
hkushner7
Door Lock Issue
Hi all! Sorry if this has been answered before, I've searched and not found an answer.
I've got automatic locks that will unlock but not lock. It is a problem with all doors and all switches. Could it be the relay? If so, could someone tell me where to find the relay? Thanks!
Old Aug 20, 2018 | 08:04 AM
Teutonics's Avatar
Teutonics
It could be the relay, or the signal wire to the relay, or the wire from the relay back to the actuators. If it also doesn't work using the remote fob, then that probably eliminates the signal/switch wire to the relay.
One thing to try (that surprisingly worked for me when my fobs stopped working but switches still worked) is to pull the fuse for the locks for a few seconds and reinsert. The only thing I can guess is that it reset the control module and the fobs started working again. It may not work for you, but it's a cheap and easy thing to try first.
Old Aug 20, 2018 | 12:50 PM
hkushner7's Avatar
hkushner7
Thanks! I'll give the fuse reset a try, since I at least know where that is. Any chance you know where the relay might be on a 2007 model?
Old Aug 20, 2018 | 01:18 PM
Teutonics's Avatar
Teutonics
Somewhat guessing as I assume the relay is in the control module, but if it helps the control module should be behind the trim panel just rearward of the driver door. (that's where it is in the 2006)
Old Aug 22, 2018 | 11:03 AM
BigBlue 94's Avatar
BigBlue 94
The rear door switch (If equipped) can cause the whole system to malfunction. Check the connections on it. I had no locks working, replaced that switch, and all works perfect now.
Old Aug 23, 2018 | 09:51 PM
pancake52's Avatar
pancake52
Check rear door switch
My locks won't work if the rear door switch has been used to lockor unlock the whole van. Try recycling the rear door switch then your drivers and passenger switch should work..
wyollie
Nov 4, 2016 09:31 AM
jporterOCCC
May 6, 2011 08:35 PM
rblaine9000
25
Nov 9, 2008 08:18 AM
kahnos
Electrical Systems/Wiring
Jun 12, 2006 01:01 PM
tommyleea
Jul 19, 2004 10:18 AM
