Sponsored by: Real Truck
Transmission Cooler info
Old Aug 17, 2018 | 07:37 PM
puppyf250's Avatar
puppyf250
Just a heads up. My 01 F-450, burped out the transmission, then caught on fire from the fluid leaking onto the hot "y" pipe. Shop looked at it, determined the transmission was toast. According to the shop, (who I trust), the torque converter was so hot, it had blued in places. Turns out, my aftermarket transmission cooler had gotten clogged at the intake side, due to debris from wear in the transmission. This caused the transmission to overheat, and basically die on me. Thought I would pass this along to you guys with high mileage transmission. Maybe check your coolers every now and then. This transmission had been replaced 16,000 miles ago, but, I don't know if cooler was serviced. Hope this saves someone the pain of a new transmission.
Old Aug 17, 2018 | 10:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can't service a cooler. They need to be replaced when the trans is replaced or rebuilt. If you don't do that, you get what happened to you.
Old Aug 18, 2018 | 09:16 AM
bwguardian's Avatar
bwguardian
The person that replaced the transmission should have tested the atf flow prior to letting it hit the streets.
SoCalAngler
Aug 13, 2020 10:52 PM
tnwill
Oct 26, 2007 04:35 PM
nubwon
Sep 21, 2006 10:15 PM
rbastedo
Aerostar
Jul 27, 2004 12:18 PM
