Zf5 swap
Old Aug 16, 2018 | 09:13 PM
Jzisakis's Avatar
Jzisakis
Zf5 swap
I have my eyes on a 1987 2wd zf5 transmission that was mounted to 6.9 idi. I want to swap it into my 1984 2wd t18 6.9idi. Trans will get rebuilt and converted to SMF before the install. From what I understand The only difference is the 1987 floor pan is taller and the 1987 transmission crossmember is farther back. I'm 19 (bought the truck at 17) and this is my first and last truck. Everything is getting done right.
Questions-
what smf conversion is best?
can I just redrill the frame and use my t18 crossmember?
am I missing anything?
Old Aug 17, 2018 | 05:37 AM
tecgod13's Avatar
tecgod13
Use the LUK smf, it has a great pedal feel and is high quality. I much prefer it over the Southbend that was installed in my '93 by a previous owner.
Redrilling the frame is fine, but I'm not sure what the t18 crossmember is like in comparison to a zf5 crossmember.
Congrats on your first truck, I guarantee it won't be your last, but great spirit!
Old Aug 17, 2018 | 08:33 AM
Chevy_Eater's Avatar
Chevy_Eater
You should get the cross-member for the ZF, it'll make life much easier.
Skip down to post #33:
https://www.ford-trucks.com/forums/1...t-truck-3.html
There is another recent thread from another forum member that did the swap and modified his T19 cross-member to work, but it required cutting and fabricating. You can search fro the thread if you're interested in that route.
jkalin99
Jul 24, 2017 08:45 AM
59 Freak
Jan 31, 2011 11:43 AM
rpemsweet
Jan 11, 2007 07:24 PM
51dueller
Apr 18, 2006 09:11 AM
