Need recommendations for fuel injectors
can anyone tell me what company makes the best fuel injectors for my truck?
im assuming that we use Bosch....
Also,
1. is it hard to change the injectors on the right bank?
2. does the intake plenum have to be removed to get access to the right bank injectors?
this is for a 1986 Ford e-150 302
I bought my injectors off ebay. Wherever you can get them the cheapest.
I just looked on Rockauto, those things are not cheap. Is there a good reason you need to change them? I took a set to the Ford dealer and they had a injector test machine, and they charged me like $40 to check some injectors awhile back. They can check spray pattern and flow, and make sure they turn off without leaking. They also put some powerful cleaner through them with the machine also. I took the injectors off myself, so all they had to do was plug them into the machine and check them.
thank you for your response!
The reasonings behind it is that I was thinking of buying a OTC 3398 Fuel Injection Pulse Tester and test them but the access to the injectors is so tight that I figured I should just spend the time replacing them!
this van has 155,000 miles on it and I don’t think they’ve never been changed....
ill wait to hear what the other guys are saying here
Injectors can be cleaned and electrically tested.
FYI; Don't buy injectors that exceed the flow rate of the stock injectors or you will flood your engine.
https://www.cruzinperformance.com/fuelinj.html
He sends you a neat little before and after test results chart. Mind you they were for a Toyota 22RE engine, not a Ford.
There was nothing wrong with the injectors that I know of, but I was rebuilding the engine, and with everything else being new, I also wanted fresh injectors and injector seals, etc.
I wouldn't worry about them too much at 155,000 miles.
VjSimon I just thought doing this as a maintenance...
I figured it would be a difficult job and I just wanted you guys to confirm it and you kind of did!
I looked at the wiring schematics of the fuel injectors and pins number 58 and 59 seem to control the injectors.
1. Is there anyway I can hook up a fuel injector tester to test each one separately by hooking up the tester to either the number 58 pin or 59 pin?
2. Any other way to test them with out removing them?
i dought it would work
my thought was to separately back probe each injector and use the otc injector tester to run the test....this way I don’t risk breaking the connector and it’s quicker!
any thoughts on doing it that way?
But at 155K miles I would not bother replacing them unless you have a dead cylinder or the cylinder balance self test shows an issue.
i was watching Eric o of south main auto on YouTube he basically tested all the injectors to see which one had the lowest drop
quick question
i have a snapon mt 2500 scanner with all the personality keys and cartridges....
just wanted to confirm,
there is no way for this scanner to communicate with our (beautiful....) EEC-IV system, right???
I know guys, all we can see are the codes and a wiggle test
its so frustrating not to be able to see the perimeters I know it’s obd1 but still....
quick question
He is just flow testing the injectors, you do need to do this with Ford's as the ECU tests for it in the cylinder balance test, this is a function GM or Chryslers system did not offer and this hence the need for the above test with the OTC tool.. The Ford OBD I has much more advanced system for load calculations and fuel delivery than the GM or Chrysler system did, the ECU can tell you that same info in the cylinder balance test, plus it still does not let you see the spray patterns, something the Ford OBD I system usually picks up in the cylinder balance test if one injectors spray pattern is wonky. Ford's Pre EEC V (OBD II) systems did not offer sensor data streams to scan tools and requires a breakout box between the ECU and engine harness to read the data streams to/from each sensor/injector. The break out box has advantages as it makes it way easier to find harness faults and ECU faults as well as allowing you to read the actual the data stream. Over all the Ford system was far more reliable than what GM or Chrysler was using but it was more sensitive to ground issues.
yes that’s exactly what I want to do!
so I can test for cylinder contribution with the snapon mt2500???
ill hook it up tomorrow and update you guys if I was able to do the test
do u know what else can be done with this scanner besides codes and a wiggle test???
2 banks of 4 cylinders, 4 injectors fire, then the other 4 injectors fire.
1,4,5,8 is tied to one bank and 2,3,6,7 are tied to the other bank.
The Ford injector testor at the shop test the flow rate also. But like was said, they must come out to do all the tests with the machine they have.
thank you for your response and right what you suggested is a good idea!!!
on a different note, for you and all the other owners of the trucks here
i just wanted to share an issue I had with my van.
the ac drain was draining on to the O2 Sensor connector
water got inside through the forth open hole of the connector
so I sealed the hole and added a hose to extend the drain
I suggest everyone checks their AC drain and extend it by attaching a hose that redirects the water down to the ground
