18” vs 20” Wheels
Old Aug 19, 2018 | 09:24 PM
  #31
rtraviator's Avatar
rtraviator
Originally Posted by SDcrewzer
Also, trucks with 20” wheels and tires are fitted with an 18” wheel and smaller tire as a spare.
Will the spare tire location accept a 20” wheel/tire?
Old Aug 20, 2018 | 01:32 AM
  #32
bushpilot's Avatar
bushpilot
https://www.ford-trucks.com/forums/1...ize-spare.html
Old Aug 20, 2018 | 02:44 AM
  #33
OneCylinder's Avatar
OneCylinder
Everyone has an opinion, but ride quality will have a lot more to do with tire brand, type and size than the one inch of rim vs tire at the sidewall. To achieve the same ride heigth, an 18" rim will require more sidewall a larger aspect ratio. A 20" rim will will require less sidewall a smaller aspect ratio (less rubber/less weight). Generally speaking at the same ride heigth a 20" rim and tire will have less rotational mass and therefore more efficiancy, better fuel mileage. That is why auto manufacturers now engineer larger rims and less rubber, also shorter sidewalls provide for better handling and performance. Look at the trend in all racing venues that require cornering. True, taller sidewalls will absorb more shock when off-road. I went from 275/70/18 to 295/70/18 to fill in my fender wells some; I lost 2-3 mpg. Recently I went from the 295/70/18 to 275/65/20 (these wheels are approximately the same heigth) and gained my mileage back.
My 2 cents worth.
Old Aug 20, 2018 | 08:49 AM
  #34
gravedgr's Avatar
gravedgr
Originally Posted by sawtooth
Well that sucks. So worse case is that I have to change the front springs back down 1 step to go back to the standard F350 front spring rate correct? I believe the camper package only adds rear stabilizer bar as the standard F350 already comes with overload spring package. Correct?
I think that is correct, but I don't have the order guide in front of me so don't take my word for gospel. In my case, I had the HD suspension selected and decided to upgrade to the camper pkg for the sway bar since we have a bumper pull TT. I'm going to attempt to smooth out the ride with larger tires/lower pressure and better shocks on a lift kit.
Old Aug 20, 2018 | 03:52 PM
  #35
dieseldrive's Avatar
dieseldrive
It should also be noted that there are two different size 18 tires available. The standard 18's are "all season" 65 series, and the optional (required for FX4 if I remember correctly) are "all terrain" and are 70 series (taller sidewall).
Old Aug 20, 2018 | 06:51 PM
  #36
bushpilot's Avatar
bushpilot
You could be right....on our F350 (crew cab, long bed, 4x4) FX4 - the SPARE is a 275/70R 18
My other 4 tires are 275/65 R20's.
Old Aug 20, 2018 | 07:23 PM
  #37
gravedgr's Avatar
gravedgr
I hope I end up with a 275/70r18 spare. I'm going to start with just the 4 x 37s until I figure a good location for a full size spare.
Old Aug 20, 2018 | 10:35 PM
  #38
bushpilot's Avatar
bushpilot
what gears are you gonna have?
Im asking cause im trying to help a friend out - in this Thread HERE
Old Aug 21, 2018 | 07:15 AM
  #39
gravedgr's Avatar
gravedgr
3.55 is the lowest you can go in SRW. Moving to 37s converts to 3.08 if memory serves, but only if you go off the smallest tire as the starting point. There are three tire sizes available with the 3.55, so converting from the middle size (which I'm assuming the speedometer is probably set for - I doubt it is recalibrated for for the various tire options since it is almost certainly installed long before anyone on the line has any clue what tires will actually be on any particular truck) its probably more in the teens with 37s.
If I could, I would have gone with a 4.10 on the SRW. My wife's Rubicon is 4.10s with 35s and its a little more sluggish than stock, but it doesn't have 900 ft/lb.
Deadbuck
Feb 24, 2021 09:02 PM
PDX-F150
Sep 5, 2019 01:44 AM
mmikemitchell
Mar 24, 2013 10:09 PM
jrc1
2004 - 2008 F150
Dec 22, 2006 11:44 PM
cwilli
Jan 17, 2005 08:12 PM
