Motor replace 2
Old Aug 13, 2018 | 06:00 PM
Oscardagrouch's Avatar
Oscardagrouch
Motor replace 2
I replace my 73 360motor to a 390. Im near finish it has 2 loose wires ..i can' t seem to find the location I have no loose ends to connect.its coming from my solenoid. S I believe it' long enough to go under motor or by my multi function rely witch is on other end .I connect my battery positive n it put out spark the wire so it must go coil? My first transplant..its a family truck since 73 ..plus it was sitting 10 years. I need bit help as im just learning. Thanks Ford friends.
Old Aug 14, 2018 | 08:03 AM
SSStang's Avatar
SSStang
Can you post a pic?
Only a few wires connect to the engine.
Coil
Coolant temp
Oil pressure
Starter well thats a cable
Des it have A/C?
bigoldtruck
Nov 12, 2018 09:42 PM
73 ford guy
159
Dec 20, 2010 06:23 PM
sofob0909
17
Dec 25, 2009 05:58 PM
RES94025
Jul 15, 2005 11:29 AM
