maybe old question
Old Sep 23, 2003 | 07:55 AM
xfoa_chad's Avatar
xfoa_chad
maybe old question
I have a friend that bought a 351 truck truck motor to put into his 98 v6 mustang .. his question is can he put a cobra upper on a truck lower?
- xfoa_chad
www.xfoa.net founding member
Old Sep 23, 2003 | 09:18 AM
fishin1976's Avatar
fishin1976
maybe old question
No, the mountings are different. You could, however, get a 95-96 5.8l intake (upper and lower) and use many of the that trucks parts to create a monster. OR, just build the engine with good heads, cam, dual plane intake and 600-750 CFM carb. The problem would then be getting a tranny combo since all of the trans are electronic.
Best bet: get a donor 95-96 5.8L 2WD truck with the matching E4OD or 4R100W tranny and swap both to the mustang. You would have to make custom drive shafts and crossmembers to accomodate the different trans.
Why doesn't he just find a 93-up lincoln with the 4.6L and swap that in, it would just about be a bolt in. The mustang 4.6L cobra intake would bolt right up to that engine.
Good luck!
Old Sep 23, 2003 | 10:31 AM
MuchToMyDelight's Avatar
MuchToMyDelight
maybe old question
So would the supercharger!!
Old Sep 23, 2003 | 10:58 AM
xfoa_chad's Avatar
xfoa_chad
maybe old question
he has a t-5 tranny that he will be using and a 393 stroker kit and afr heads the problem lies with the truck intake is facing the wrong direction ....
- XFOA_Chad
www.xfoa.net
Old Sep 23, 2003 | 12:41 PM
fishin1976's Avatar
fishin1976
maybe old question
You will need the correct bell housing for the T-5, are you sure its a T-5? I thought that there was another 5-spd tranny used on V6 mustangs. 351s were rare with a manual trans, finding a flywheel may prove difficult. I think you may beable to use a pre-80's 302 flywheel (28oz balancer, 81 and up are 50oz.).You'll need a new clutch, clutch master cylinder, slave and linkage most likely. That should give you something to chew on for a while.
Old Sep 23, 2003 | 11:42 PM
Jimbo302's Avatar
Jimbo302
maybe old question
You can buy the 28oz flwheel or flexplate, no problem there. The T5 aint gonna last though, and there is no way you are fitting an E4OD in a Mustang.
He is using the truck intake? That lower is a small oval port design. It is going to be a bottleneck on that setup. As for an upper. I have heard a stock mustang 302 upper will fit, never tried it though.
Old Sep 24, 2003 | 07:28 AM
xfoa_chad's Avatar
xfoa_chad
maybe old question
i will post him a message on my site today.. the v6 tranny is not going to last but his last big expendature was the 393 stroker kit.
i think i will tell him to look at getting a TFS upper and lower
- xfoa_chad
www.xfoa.net
xfoa_chad
Georgia Chapter
Jun 10, 2005 05:22 AM
xfoa_chad
New Member Introductions
Mar 15, 2004 01:25 PM
xfoa_chad
Dec 2, 2003 08:31 AM
xfoa_chad
Dec 1, 2003 03:42 PM
xfoa_chad
Georgia Chapter
Sep 26, 2003 11:45 PM
