351 vacuum lines...please help
Old Aug 12, 2018 | 09:39 AM
frank5079's Avatar
frank5079
I've swapped in a 351 in place of my 300 six and am trying to sort out the vacuum lines. The 351 is from a '95 F250 (automatic) which I've swapped into my '94 with an M5OD, 28 oz flywheel, F250 ECM (5 speed) and so on. There are green, white, and yellow plastic vacuum lines and they are connected to solenoids. I'm trying to use both Chilton's and Haynes manuals but still need help. From what I can figure, the green line goes to the EGR. There is a red line and that's supposed to go on the FPR. That's where I need help from you guys...I've tried the search feature but have had no luck either.
Old Aug 12, 2018 | 12:11 PM
vjsimone's Avatar
vjsimone
Do you have a blue line ?
The FPR line usually goes directly to the Vacuum Tree from the FPR.
Green line to EVP Solenoid - EGR sounds right.
Red line usually goes to the Vacuum Canister.
Old Aug 12, 2018 | 12:18 PM
frank5079's Avatar
frank5079
No blue. Green, yellow, white, light pink and red.
Old Aug 12, 2018 | 12:28 PM
vjsimone's Avatar
vjsimone
Are the vacuum lines from the 300 or the 351?
Do you have a vacuum canister?
Old Aug 12, 2018 | 12:32 PM
vjsimone's Avatar
vjsimone
Do you have a map sensor ?
What color line is going to your MAP, and where does it go?
Old Aug 12, 2018 | 01:00 PM
frank5079's Avatar
frank5079
351 and I bought a new F250 plastic vacuum canister and got rid of the "coffee can" vacuum canister....
Black and it's hooked up to the manifold vacuum "tree"
Old Aug 12, 2018 | 01:11 PM
vjsimone's Avatar
vjsimone
Where is your vacuum canister connected ?
Old Aug 12, 2018 | 01:33 PM
frank5079's Avatar
frank5079
Standing from the passenger fender the right side is hooked directly to the manifold tree. The left side is hooked to a hose which in turn is hooked to the connector that holds the green, yellow, white, and light pink lines, and is connected to the white line.
Old Aug 12, 2018 | 01:44 PM
vjsimone's Avatar
vjsimone
If you can photo that connector, would be nice to look at.
So, if that red line you were speaking of is about a foot long, that would be about the length nessicary to go from the FPR directly to the Vacuum tree.
You can also run a new line from the FPR to the Vacuum Tree......
Old Aug 12, 2018 | 01:51 PM
frank5079's Avatar
frank5079
Yup. One of the guys from the f150forum.com board sent me this....
and this helps...
Old Aug 12, 2018 | 01:54 PM
frank5079's Avatar
frank5079
I forgot to mention that I have removed the air(smog) pump as well as the TAD and TAB and plugged the pipe that connects the left and right heads in the back with a same sized pipe cap. I guess I need to plug the yellow and pink lines...
Old Aug 12, 2018 | 01:56 PM
vjsimone's Avatar
vjsimone
Yeah, Steve is a great resource...
I see you have deleted your smog stuff...
Old Aug 12, 2018 | 02:08 PM
vjsimone's Avatar
vjsimone
I would follow those yellow and pink lines back to the source and plug / cap them there, adventually those lines are going to crack and leak.
So, just disconnect them from the TAD/TAB solenoids and cap the solenoid connection.
Old Aug 12, 2018 | 02:10 PM
vjsimone's Avatar
vjsimone
Are you using the Computer and MAP from the 1995 Truck ?
Old Aug 12, 2018 | 02:24 PM
vjsimone's Avatar
vjsimone
If you have access to the truck that the 351 came out of, photo the Vacuum Diagram under the hood.....
masonp
Jul 21, 2016 07:57 AM
76ClydeF100
Jan 22, 2014 12:15 PM
EDsurvivor
Feb 27, 2011 10:25 AM
vancouver island
17
Nov 1, 2009 05:46 PM
