parasitic battery draw
Old Aug 12, 2018 | 07:25 AM
waynec423's Avatar
waynec423
Hello everyone. I have a parasitic battery drain of around 2 amps on my 1995 E350 motorhome. I have traced the draw down to the ECM circuit. When you pull the main 30 amp fuse to the ECM the draw goes to almost 0. I removed the ECM , re-installed the fuse and the draw came back with the ECM totally disconnected.Removing the ECM power relay makes no difference. An ASC certified ford master tech told me the only thing on this circuit is the ECM and the ECM power relay.
Anyone have anyone suggestions , or know if anything else is on this circuit? Thanks in advance for any help
UPDATE: Found the source of the draw. Please see my other post titled "fuel pump won't shut off"
jasvid
Feb 9, 2012 07:40 AM
98expeditionXLT
Jan 17, 2011 08:26 AM
Phrosut
1983 - 2012 Ranger & B-Series
Jun 16, 2009 06:30 PM
tom2131968
1978 - 1996 Big Bronco
25
Oct 27, 2006 09:28 AM
Bergracer
Jul 19, 2006 03:41 PM
