Need Help With Manual/Power Conversion
Old Sep 22, 2003 | 01:48 PM
wilksj's Avatar
wilksj
I need to know whether or not I can use the power brake calipers and lines and/or master cylinder and Booster off of a 77 LTD to convert my 78 F100 Custom to power brakes....any help will be greatly appreciated!!!
Old Sep 22, 2003 | 07:48 PM
plowpusher's Avatar
plowpusher
if you allready have disc brakes all you have to do is apply a power booster and master cylinder from a same year truck or one that uses the same system it ain that tuff just check out a truck the same as yours at the bone yard. remember you need to grab the vacum hose and clamp and the fitting on the intake manifold
Old Sep 23, 2003 | 10:08 AM
GeneStoner's Avatar
GeneStoner
Read the "Brake Upgrade" article inthe tech articles, it will answer some of your questions even though the article is for 78-79 Broncos (basically the same truck as yours).
