learning to weld
Old Sep 22, 2003 | 11:01 PM
Vanhecht's Avatar
Vanhecht
learning to weld
whats a good way to learn to weld? i dont have tonsof free time but would like to learn...can anyone reccomend some school i could go to? thanks ahead of time my fte brethren
Old Sep 22, 2003 | 11:13 PM
Mike W's Avatar
Mike W
learning to weld
A class is probably the best but I started reading books and just went to it. Arc, mig, gas, and tig. Check out http://www.hobartwelders.com
They have some good forums. Also http://aws.org
Old Sep 22, 2003 | 11:40 PM
Oceanwave's Avatar
Oceanwave
learning to weld
I learned to weld in High School then took some night school classes at the local Technical School. It took a while but it didn't cost a lot and the certificates are real.
JK
Old Sep 23, 2003 | 02:51 AM
Torque1st's Avatar
Torque1st
Posting Legend
learning to weld
You can find information on this subject in the Garage & Workshop forum using the search function.
Old Sep 23, 2003 | 07:32 AM
Big Orn's Avatar
Big Orn
learning to weld
Go around to all your freind's shops/garages and get every kind of scrap metal they have. Then after you read-up/learn from the books/schooling then you have plenty of practicing material. First I would get a DC machine (arc) and get my hand in on that. Start out with 6011 rods (1/8" diameter). You will find at first that you have to learn how to set the heat (amperage) for each rod and thickness of metal. A good rule of thumb: Use the fractional diameter of the welding rod as a starting point then fine tune the amperage to suit your hand. Example 1/8" rod = 125 amps. You also will have to learn how to watch the puddle instead of the arc, but that comes with time. The main thing is learning the right way the first time - then you won't have to be de/re-programmed later.
Old Sep 24, 2003 | 06:33 PM
V10man's Avatar
V10man
learning to weld
Classes?? We don't need no stinkin classes! I bought a 110V wire welder and went to town. Check out that Hobart site. Can't get much easier than mig welding.
rangersvt04
Sep 23, 2008 07:20 PM
150ford
37
Dec 24, 2004 03:37 PM
bronco351
50
Jan 24, 2004 07:09 PM
