1966 F100 Firewall Rectangular Electrical Plug?
Old Aug 25, 2018 | 08:44 PM
Stormin926's Avatar
Stormin926
OK, I got the unit, drilled the hole, and am ready to start crimping the wires, however, there are 4 wires that are larger than the 20 to 18 gauge. I see your photo and the 4 wires in question look like you routed them through where the break booster/master cylinder goes. Did you route the largest wires that way? I do have a few smaller firewall holes that I could get a rubber grommet and fish them through.
Also, what do you call those wire connectors? I've seen them before, but never crimped them on. I did buy the crimping tool that they suggested. Any helpful info on crimping these type of connectors?
Old Aug 25, 2018 | 09:29 PM
gcooter's Avatar
gcooter
I don't know how much they changed from the 1964 to the 1966 but here is the plug and where the wire go fot the 1964 trucks.
Wiring for the 1964 trucks.
Old Aug 26, 2018 | 07:19 AM
Stormin926's Avatar
Stormin926
Thank you for the wiring diagram. That will help with rewiring some of the old plugs with the aftermarket wiring.
Old Aug 26, 2018 | 10:55 AM
vze2c2gb's Avatar
vze2c2gb
Hi Stormin926,
Yes we did route the 4 larger gauge wires using a single hole firewall plug and retainer I purchased on Mac's. The hole we used was a knockout just above where the speedo cable comes out of the firewall. They call them Weather pack and Metri-pack terminals. I attached a pic with some info on crimping the pins, my suggestion try practicing a few on some scrap wire till you get it right. Any further questions just ask good luck.
Last edited by vze2c2gb; Aug 26, 2018 at 11:15 AM. Reason: speedo not park brake cable
Old Aug 26, 2018 | 10:59 AM
gcooter's Avatar
gcooter
Your welcome. It is always nicer to know where the wires are coming from and going to when you start to replace wiring. It looks as if the broken plug was headed to the Left Hand Rear Turn Signal. If you need it driving right away you could run a jumper wire through one of the round holes right above the bad plug and have your turn signal back. It should be a solid yellow wire.
Old Aug 26, 2018 | 12:54 PM
Stormin926's Avatar
Stormin926
All good information! Thank you all. I definitely need to practice first. I'll keep you posted.
old farm truck
General Automotive Discussion
Jan 20, 2019 10:18 AM
dmanshane
Dec 31, 2011 12:59 PM
whitesdford
Mar 7, 2010 10:34 PM
AndeyHall
Dec 1, 2009 06:46 PM
cbfomoco
Feb 7, 2007 10:04 PM
