I have a 2000 f350 7.3
it has about 210000 miles
3 times in last month my truck runs fine then out of nowhere I lose all power.( it dies)
i have electrical everything works and cranks but won't start
next Day it runs fine.
diesel shop couldn't find any codes or faults and ran fine for them.
it us getting fuel to fuel bowl on top where filter is.
could it be a cam sensor?
Relat?
Another sensor?
since getting fuel to motor I was filling out fuel pump or sending unit.
any thoughts
thanks in advance
Does the engine just stall? Is there an SES light? Are there any other symptoms? Does it eventually (could be one cycle of the key or a few minutes later) restart with no issues/symptoms?
Could be a CPS if nothing else is going on.
Engine-related items I recommend posting in the 1999 - 2003 7.3L section. Lots of smart people over there to help you down the path to fix the issue.
