Changing Fuel Filter
Old Aug 12, 2018 | 04:31 PM
SkiSmuggs's Avatar
SkiSmuggs
Originally Posted by senix
Just changed mine (the filters) yesterday. I had been neglectful and had 19K on the filters. Using oil on the o rings helped mine to come off very easy, even after that many miles.
I just use a socket for mine. I can do the lower filter easier than I can the engine top filter. If it took 5 minutes, I'd be surprised.
Neglectful? My manual says every 22K and that's what I did.
Old Aug 14, 2018 | 10:38 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Just remember to tighten the Separator Cap until it stops. You get a number of codes if you don't tighten up all the way.
Old Aug 14, 2018 | 08:54 PM
kper05's Avatar
kper05
22k is within the normal requirements. Many of us follow the severe (special) duty for fuel filters though. I'm not more knowledge than the engineers but with a fuel system repair between $9k to $10k (indirect experience on an F350 DRW) and my own observations on seven filter kits or so, it seems like a good idea to keep the filters clean. I'm changing fuel filters every other oil change, which run around 7,500 miles each per the IOLM.
Old Aug 14, 2018 | 08:56 PM
senix's Avatar
senix
Yes I follow or was suppose to follow the severe schedule due to heavy towing.
Old Aug 14, 2018 | 09:28 PM
k7lvo's Avatar
k7lvo
There’s more opinions on fuel filter changes than on oil/filter changes, I think. Some have said they change fuel filters when they change oil.
The (2017) filter on the right has about 25,000 miles on it. I use Petro/TA fuel almost exclusively.
Old Aug 15, 2018 | 06:00 AM
senix's Avatar
senix
Didn't take a pic of mine, but it was a bit darker, but still clean, course i am running the other type of filter so the filter media may effect the color?
eergin
Apr 24, 2018 02:03 PM
Russman206
Jul 7, 2017 04:03 PM
wwanderson555
19
Mar 30, 2015 11:58 PM
gsxr1300
6.7L Power Stroke Diesel
24
Jul 27, 2014 08:15 PM
rdually
Oct 14, 2003 11:31 PM
