Turbo problem??
Old Aug 5, 2018 | 07:20 AM
green_95's Avatar
green_95
Turbo problem??
Got a 97 f250 7.3 5 speed, and I've noticed as of late and seems like it's getting worse, that at low rpm's or when I'm pulling out from a atop and trying to get up to speed that if I give it to much fuel that the motor boggs down or almost stutters until the rpm's get built up. Is this a turbo or injector issue?
Old Aug 5, 2018 | 11:05 AM
97-psd's Avatar
97-psd
Have you checked the fuel pressure yet?
Old Aug 5, 2018 | 11:07 AM
oldbird1965's Avatar
oldbird1965
Low rpm's turbo is not spooling so are you saying that once the turbo spools the stutters go away? It could be an injector problem too, how many miles on your injectors?
Old Aug 5, 2018 | 02:49 PM
green_95's Avatar
green_95
Yes, once rpm's get built up the stutter goes away. 197k miles on the truck, I'm assuming it's the original injectors. I have not checked the fuel pressure,I did put a new fuel pump.on it last year cause the old one was leaking.
02expy
Apr 1, 2019 05:23 PM
alteredspeed
Sep 19, 2008 11:12 PM
Pigeon
Feb 26, 2006 11:03 AM
Mikey85
Jun 12, 2005 10:56 PM
mhalter
Jul 29, 2004 11:51 PM
