FUEL PUMP RELAYs
Old Aug 1, 2018 | 12:36 PM
harley4jcs's Avatar
harley4jcs
FUEL PUMP RELAYs
2000 X, V-10 : How many relays does it have & locations please?? I'm finding info that is all over the place but I know it can be put to bed here
Thanks
Old Aug 2, 2018 | 08:50 AM
projectSHO89's Avatar
projectSHO89
Why would you think there's more than one?
Old Aug 2, 2018 | 09:01 AM
harley4jcs's Avatar
harley4jcs
I'm trying to run down a poss fuel pump problem. Looking around at all the info: (1) in the power block as you noted (2) behind the radio in the dash keeps showing up & (3) behind the right side kick panel (fuel cut off switch) to look at as well. So I am wondering if the X has the one behind the radio also ??? Thanks
Old Aug 2, 2018 | 10:36 AM
projectSHO89
That diagram was straight out of the factory service manual for the vehicle you specified. Go out and look at your truck and compare it to the diagram. If it matches, you're done. If it doesn't, either the factory manual is wrong or there's an error somewhere else.
The location of specific components varies with the year and the model. Limit yourself to EXACTLY what you have to be safe. Otherwise, you're going to get confused by assuming that similar models or years will be the same and you will end up chasing your tail out in the weeds.
Monster-4
Modular V10 (6.8l)
Nov 4, 2013 08:17 AM
Yaga1973
1983 - 2012 Ranger & B-Series
Sep 8, 2012 01:35 PM
butch h
Escape & Escape Hybrid
Sep 19, 2011 06:28 PM
PauL3861
21
Aug 22, 2011 11:08 PM
Joe, IN
Bronco II
Oct 11, 2003 08:09 AM
