Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
p0231
Old Sep 17, 2011 | 06:26 PM
butch h's Avatar
butch h
p0231
My '02 Escape quit running, abruptly the other day. It will start on starting fluid, so I'm reasonably sure it is fuel related. What is the most likely problem that would set the p0231 code?
Thanks,Butch
Old Sep 18, 2011 | 08:07 AM
wptski's Avatar
wptski
Thanks,Butch
That code is for "Fuel Pump Secondary Circuit Low".
Old Sep 19, 2011 | 05:42 PM
butch h's Avatar
butch h
Thanks, but where is this secondary circuit? If I were to put 12 volts directly to the pump assy. ,would it operate?
Old Sep 19, 2011 | 06:28 PM
wptski's Avatar
wptski
I have no idea whatn they mean by secondary circuit.
They don't seem to have a detailed diagram covering the FP in the manual only a crude block diagram. It shows the FP relay powering the FP and PCM, so it sounds like that's not it. There is the inertia fuel cutoff switch. It's possible that has tripped or faulty. Look in your ownwer's manual for location.
I'm working on a old GM product right now and it has FP Prime Test Lead. You connect it directly to a +12V source to run the pump constantly.
Found a simple diagram.
manasota
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 13, 2021 07:00 PM
51fordf5
Oct 5, 2018 09:45 AM
ex_cursion
Jan 31, 2011 03:16 PM
chris 2
Sep 11, 2006 08:03 PM
cow_rancher
Jan 17, 2006 05:45 PM
