Poor Mans DPF Delete
Old Jul 31, 2018 | 10:50 PM
Powerslide's Avatar
Powerslide
Looking to do a barebones DPF delete. Can it be done without a tuner?
A: don’t want a performance tuner signature on my ECM .
B: Not interested in any HP gains.... yet
I would weld up a muffler assebly w/ flanges to replace the DPF. In the event of a warranty claim I could swap the filter back in and play dumb.
Other than a SES light, will doing this cause any drivability or other issues eg. Limp mode? Waste fuel in the exhaust stroke?
My understanding is the DPF regen is initiated based on values of a pressure sensor between the filter and turbo. With filter removed the values should never get high enough to trigger a regen. Or is there other factors that initiate a regen?
Old Jul 31, 2018 | 11:25 PM
mhoefer's Avatar
mhoefer
Without a tuner it will throw codes from the NOx sensors, EGT probes, detection of soot, amd ..... eventually, going into limp mode due to issues with the sensors and emissions. You at least need a tuner to delete the sensor issues. If your going to delete, you actuallly need the tune so you can delete EGR, DPF and DEF systems and sensors,you need block off plates and dummy plates. Sorry to burst the bubble, but that is what I think will happen.
Old Aug 1, 2018 | 09:22 AM
brandon4's Avatar
brandon4
Tried it on an 08. Just blew white smoke continuously. A lot of it.....
Old Aug 1, 2018 | 09:38 AM
BK39's Avatar
BK39
And run right, no.
Old Aug 1, 2018 | 02:35 PM
fordman19762003's Avatar
fordman19762003
Everything on these newer diesels is tied into the ECM and you can't make any drastic.changes without causing issues. You're going to need a tune to allow the motor to run without the emissions systems intact.
Old Aug 1, 2018 | 02:57 PM
Powerslide's Avatar
Powerslide
I dropped in to see local service manager, He has same truck deleted -no after market tuner. They will honor warranty so long as theres no performance tuner sig on the ECM. Going to meet with him next week to discuss. There is a way around paying $$$$$ for a tuner.
Had bad experiences with Tuners, 4 of them laying around here (Bullydog (x2), SCT, AFE) from previous vehicles. Every one had some kind of glitch, tech support is terrible. Seems the only reliable one for our trucks is EZlynk and even that has its glitches.
Old Aug 1, 2018 | 03:44 PM
wicked 2018's Avatar
wicked 2018
Find this very hard to believe. Please prove me wrong.
Old Aug 1, 2018 | 03:56 PM
jergle's Avatar
jergle
"They will honor warranty..." I think you better get that in writing!
BenFranklin's Avatar
BenFranklin
I'll second the motion.
That is of course...unless this guy used IDS and disabled the sensors that way? Regardless, I cannot possibly see how they could keep a warranty intact; there is simply too much liability.
Old Aug 1, 2018 | 04:04 PM
Powerslide's Avatar
Powerslide
Ya never know... I’ve had this guy program a 6.0 in an engine cradle I made for a fracking pump.
Old Aug 1, 2018 | 04:15 PM
Strokin-A-2010's Avatar
Strokin-A-2010
Wow.......some people should not own diesel trucks.I mean come on EVERYTHING in the powertrain or emissions is run through the ECM. You can't delete anything without a tune. And if someone told you they have they are full of it.
Old Aug 1, 2018 | 04:25 PM
Powerslide's Avatar
Powerslide
And some people should just keep on trolling if they have nothing useful to say.
Old Aug 1, 2018 | 06:48 PM
ford390gashog's Avatar
ford390gashog
I wonder if you could in theory use IDS and a different vin ro upload the ECM file for an export market truck. Ford makes the 6.7 with no emissions equipment for export.
Old Aug 1, 2018 | 08:00 PM
wb6anp's Avatar
wb6anp
That's all well and good IF your not on the road somewhere and you break down, What are you going to do have it towed 1000 miles back to your specific dealer to get it worked on? Every dealer isn't going to honor what your service manager said. Your going to be stuck just driving your truck locally.
Old Aug 1, 2018 | 09:16 PM
Blwnsmoke's Avatar
Blwnsmoke
He isnt trolling, he is speaking the truth. 12 model years of deleting and they all needed a programmer. You can run a stock tune regarding power and shifting but you still need a tuner to download the changes and shut everything off.
If you dont want the answer to your question, dont post.
