Does anyone have Ford part numbers for the body mounts for a 2000 Econoline or know of aftermarket replacements? Doorman lists that they have them though the ones at positions 3-5 look nothing like the stock ones in mine as shown below. The info from Doorman basically indicates the same mount used at position 2 can also be used for positions 3 and 4. If that's the case I'd rather see if I could find the Ford part for position 2 and use them in position 3 and 4 as I'm not sure how long the Doorman units would last. Has anyone used these donut style mounts successfully in place of the stock Ford mounts in locations 3 and 4?
Thanks JC. I’ve got that service manual as well. None of those part numbers show any results when searching online though. I haven’t been to the dealer yet so will see what they say I guess.
hi!
very late reaction from a desperate guy XD
Did you still manage to find replacements for these weird type body mounts?
greetz!
Econowizard
Hi. I did find replacements but no idea what I ended up using. I should have receipts though so will take a look and let you know.
Cool! Many thanks in advance! Im mostly curious if they're the rubber disk type everyone knows, or an adaption of the "rubber in cylinder" type, since that one is very hard to find (for me at least XD)
Hi. I took a look at my receipts as well as looked under the van and I did install the Doorman rubber donut style mounts in every location. Haven't had an issue with it yet!
Shawn
Thank you very much! I took the original parts to a garage and all i got was them scratching their heads over it XD
I'll tell them i have found a replacement!
thanks again, have a good one!
