Starts sometimes, sometimes not
Old Sep 22, 2003 | 06:54 PM
elstx's Avatar
elstx
Truck had new battery, alternator, carb rebuild, etc. Sometimes it won't start, wait awhile and it starts right up. Usually sounds like battery is weak, but it's not. Any ideas?
Old Sep 22, 2003 | 07:18 PM
mypa'struck's Avatar
mypa'struck
When does it do this? Only after it's been run awhile or also when it's cold? My truck does something similar, but only after it's been run awhile. In my case, I think it's vapor lock.
Dennis
Old Sep 22, 2003 | 07:20 PM
elstx's Avatar
elstx
usually after it's ran awhile, but sometimes when it hasn't
Old Sep 22, 2003 | 07:28 PM
mypa'struck
well, just as a precaution, check to see if any fuel lines are near heat sources and if they get hot when it's been run awhile.
Electrical problems are a pain in the ****, if that's what it is.
Dennis
Old Sep 22, 2003 | 08:02 PM
MuchToMyDelight's Avatar
MuchToMyDelight
Sounds like the timing is too far advanced. Not much, maybe 2 degrees. Try moving the distributor just a tad counter-clockwise.
Old Sep 22, 2003 | 08:17 PM
elstx's Avatar
elstx
Just had carb rebuilt and timing set.
Old Sep 22, 2003 | 08:49 PM
fricker's Avatar
fricker
sounds a lot like you have a bad spot in your starter windings. I've had the same problem with several vehicles. especially my 91 f 150. after you run it for awhile it sometimes wouldn't turn over fast enough to start it... seemed like a bad battery... many new batteries later i found out it was a starter. Hope this helps.
Josh
Old Sep 22, 2003 | 09:46 PM
gtex's Avatar
gtex
I assume you put in new wires to the battery and starter! Make sure the ground wire is new and the connections are good and clean.
Old Sep 22, 2003 | 10:17 PM
elstx's Avatar
elstx
No, not exactly. The hot wire is new, and the starter wire is new. Could a bad ground wire cause that?
Old Sep 22, 2003 | 11:27 PM
jor's Avatar
jor
If this happens after you have driven the truck and shut down, it could be the starter. Some of the FEs with headers tend to fry starters and they display this symptom.
jor
Old Sep 22, 2003 | 11:32 PM
elstx's Avatar
elstx
Could be it. Put the starter heat wrap around it and seemed to work good for awhile. It's impossible to get at the starter with the headers wrapped around it. Cost a ton to get it changed due to the headers, since I can't get to it myself.
Old Sep 23, 2003 | 01:56 AM
willowbilly3's Avatar
willowbilly3
If the bushings are worn in the starter it can drag when it is warm due to expansion.
