Air Compressor
Old Jul 28, 2018 | 10:41 PM
jsduty's Avatar
jsduty
Air Compressor
Hello, Anyone have a idea how big of a air compressor we can run off the in dash 110 outlet? 2018 XLT ? THANKS
Old Jul 28, 2018 | 10:47 PM
wrvond's Avatar
wrvond
Well, I can tell you that my Sears 3 gallon compressor would NOT run on it.
Old Jul 29, 2018 | 12:42 AM
18CCLBKR's Avatar
18CCLBKR
None... It won't even run a handheld vacuum. You'd have to find one that only runs on 300watts (I know it says 400watts). If you need air find a 12v solution(small supply) a genny or a gas powered one (huge air supply). That outlet is for really small electronics. No power tools.
Old Jul 29, 2018 | 06:24 AM
jsduty's Avatar
jsduty
Thanks, I hope it will run a coffee maker
Old Jul 29, 2018 | 08:19 AM
wrvond's Avatar
wrvond
Mine does run the hand held vacuum with no problem. It's one of those Bissell 3-in-1 vacuums.
Old Jul 29, 2018 | 08:36 AM
6.2caribou's Avatar
6.2caribou
I've run both a Dremel tool and a Kobalt 12v/120v auto air compressor off of my 110v receptacle, along with my Dewalt 20v battery chargers. Watts basically equals amps X volts (disregarding power factor for this), so you should be able to run up to a 4 amp motor.
Old Jul 29, 2018 | 09:10 AM
Busa 1 Dave's Avatar
Busa 1 Dave
Problem is the larger higher volume ones will draw more than the low powered inverter will allow. Mine hooks up through the battery posts...... Mine is the Viair 40047 400P-RV Automatic Portable Compressor Kit
Old Jul 29, 2018 | 10:07 PM
Lees350's Avatar
Lees350
I just purchased one of these. Ridgid Battery Compressor It will pump up 4 trailer tires from approx 50psi to 80 psi on the charge of two 3amp batteries. I know cause I had to reprogram my TPMS for the 5th wheel. I had to let the tank fill up numerous times because of the small capacity. But its only 20 lbs and did the job, so great to bring camping with us.
Old Jul 29, 2018 | 11:44 PM
ford390gashog's Avatar
ford390gashog
Mine won't even run my Milwaukee battery charger.
Old Jul 29, 2018 | 11:56 PM
djjoshuad's Avatar
djjoshuad
that shouldn't be a surprise. the M18 chargers I have are 2.75A continuous draw. that's 330W assuming a full 120VAC. the inverter is only rated for 300W continuous draw, 400W peak. 330 > 300.
Old Aug 1, 2018 | 09:39 AM
BHPR's Avatar
BHPR
Don't even think about trying a coffee make......
Old Aug 1, 2018 | 10:31 PM
jsduty's Avatar
jsduty
Wondering if one could upgrade the inverter in the stock location to produce more power.
Or just keep the little door closed on the dash
Old Aug 2, 2018 | 08:52 AM
djjoshuad's Avatar
djjoshuad
it can definitely be upgraded if you need that sort of thing. Although it would be much easier to just install a second (or third?) one in a different location. They're not too expensive.
Old Aug 2, 2018 | 11:47 AM
Tricon's Avatar
Tricon
Just install a permanent 12v compressor, they are pretty powerful, can have a 3/5 gallon tank if you want to have a lot of air on tap, and are super handy. Then you know you always have your compressor with the truck and it will air up tires/bags a million times faster than a dinky dash plug one. My tank rests at 150 psi, so I can blast a tire or bag full crazy fast.
Old Aug 2, 2018 | 05:42 PM
jsduty's Avatar
jsduty
I'm looking into a portable viair compressor, So I can use it with my jeep as well.
Just originally thought that 110vplug would work with a pancake compressor.
THANKS for all the replies.
