cleaning throttle body
Old Jul 27, 2018 | 10:09 PM
Hanks other son's Avatar
Hanks other son
I picked up an intake, plenum and throttle body from the wrecking yard and it was dirty inside the runners so i cleaned the intake and plenum but when i came to the t/b there is a sticker on it warning Do Not Clean inside t/b special coating on plate and bore. this truck had issues with oil, because from the egr on it was nasty. so my question is can this crude be better than my cleaning the t/b in the solvent sink, and it's not a harsh solvent more like kerosene.
Old Jul 28, 2018 | 09:04 AM
timbersteel's Avatar
timbersteel
Just use a soft cloth or mild detergent to clean the bore and blades.
I only use a cloth to clean the TB's.
Old Jul 29, 2018 | 01:00 AM
Hanks other son
when you say mild detergent would super clean and a rag be to much? because dawn detergent really aint gonna cut it. but if that is my only choice then that is what i'll do, i thank you for the advice as i've never come across this problem before. any idea what they mean by special coating, like what is it comprised of and or what does it do? make the air slip thru easier? just curious and wanting to learn. thank you for your help and any suggestions. Brian W.
Old Jul 29, 2018 | 03:06 AM
Skip1970's Avatar
Skip1970
sounds like a buncha mumbo jump, throttle body cleaner should work or maybe soaking it in simple green.
Old Jul 29, 2018 | 07:59 AM
timbersteel
What "sounds like a buncha mumbo jump"?
Onions.n.Butter
Jun 10, 2019 05:57 PM
jimw411
1983 - 2012 Ranger & B-Series
Jun 26, 2005 06:54 AM
JAYW
1997 - 2003 F150
Feb 23, 2005 04:59 PM
magic-dot
Jul 4, 2003 08:56 PM
Beast12
Aerostar
Jun 16, 2003 04:59 PM
