Sponsored by: Innova
Image Dynamics your thoughts?
Old Sep 22, 2003 | 06:39 PM
FizzBRFD's Avatar
FizzBRFD
I just installed a Image Dynamics 10" IDQ10V.2 D2 in a SUBBOX.NET downfiring box (.55 cu ft), Pioneer 8500 CD player, MA AUDIO M186i amp. It hits hard, but its a little distorted listening to bands like Korn, System of a Down, Metallica, etc.... Could it be the amp? Would a better amp make it sounds better?
SUb Specs:
250/500
Dual 2 ohm
13.2 mm
.25 - .50 cu.ft
Old Sep 22, 2003 | 10:53 PM
optikal illushun's Avatar
optikal illushun
turn down the gains a little. could also be a slight leak in the box itself.
Old Sep 23, 2003 | 03:32 AM
luvdeftonz's Avatar
luvdeftonz
Yeah, check the box for a leak. Check around the gasket/flange where the sub is mounted, and check the points at which the box is glued/screwed together. Also, recheck your gains...and crossovers. Also, how much clearance between the sub and the floor? I'm hoping it's at least 3 inches. I'm thinking it's your amp clipping the signal. Double check the inside and outside of the boxes joints. Reseal them with some liquid nails, just to be safe.
BTW, what is your crossover (LPF) set at and what "position" is your gain/sensitivity set to?
Old Sep 23, 2003 | 06:31 PM
FizzBRFD's Avatar
FizzBRFD
I checked all the suggestion and found the X over was set to full, simply switching it to LPF made a ton of difference. I am still tinkering with the gains ect.. Thanks for the help guys
GM4WALLS
Mar 1, 2013 08:02 PM
PowerstrokeJunkie
Oct 4, 2007 01:22 PM
bigdog4362
Feb 26, 2004 08:45 AM
RICE H8R
Dec 17, 2003 08:28 AM
1979F150
Jul 17, 2002 03:13 PM
