Code P0303
Old Jul 27, 2018 | 11:29 AM
Badcreek's Avatar
Badcreek
Code P0303
Hello n thanks for any insight you can give. I have a 2007 ranger 2.3 I've just started getting a misfire on cyl 3 and noted it only comes up if I start the truck with the AC on. It will run rough at idle then smooth out but the code shows up. I can erase the code and crank the truck with The AC off and all is fine no code or bad idle? Any help appreciated. Tks, badcreek
Old Jul 28, 2018 | 10:37 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Lots of unknowns. Is this puppy up to date on All past & present due scheduled maintenance replacement items, like plugs & wires? Maybe closely inspect the #3 plug wire & spark plug internally & externally for problems, like dirty/carbon tracking, or cracked/chipped ceramics, excessive plug gap, loose plug wire connection, damaged insulation & let us know what you find.
greenwoodford
Jan 11, 2013 05:40 PM
th3Whip
1997 - 2003 F150
Feb 6, 2012 02:02 PM
dtperformance
Dec 8, 2011 07:27 PM
DavisMT
Nov 24, 2008 07:41 AM
JADEY
1997 - 2003 F150
Feb 5, 2007 07:53 AM
