C6 Speedometer Gear?
Does anyone know what the factory tooth count is for a 1982 C6? I know you can get replacement gears for different axle ratios but I am not sure how many teeth I need. The truck the transmission came from is an all stock 82 f150.
The formula for calculating the driven gear number of teeth on the speedo cable is as such
# DRIVE TEETH x AXLE RATIO x TIRE REV. PER MI.
_____________________________________________ = # DRIVEN TEETH
1001
To calculate tire revs per mile
20168
_______________________________ = REVIOLUTIONS PER MILE
TIRE DIAMETER (in inches)
So with that
Assuming you have 7 Drive teeth in the trans
We know the tire diameter is 28.89"
So 20168 / 28.89= 698.096 And round to 698 Revs per mile.
So knowing that
we can use the other formula
7 x 3.92 x 698 / 1001 = 19.13 And to round it to 19 So you need a driven gear with 19 teeth.
Any idea how how many teeth it has?
The truck the transmission came from is a 1982 F150.
E1TP-BB ~ PGD-DL2
To figure out which DRIVEN gear is correct, the rear axle ratio is required.
E1TP-BB ~ PGD-DK2 = 1982 F150/350 351W/C6
From what I have read, there could be anywhere from 6-9 teeth on the drive gear. Maybe I’m wrong and there’s a standard number on the C6, but I can’t find that information.
but don’t I need to know the drive gear teeth so I can figure out which driven gear I need?From what I have read, there could be anywhere from 6-9 teeth on the drive gear. Maybe I’m wrong and there’s a standard number on the C6, but I can’t find that information.
I need the rear axle ratio, to figure out what the correct DRIVEN gear is.
I don't give a hoot for how many DRIVE gear teeth it has, because it has nothing to do with it, despite what someone told you!
You post the ratio, I'll post the correct DRIVEN gear and the parts catalog pic where I found it.
In my defense, you never requested the rear axle ratio nor explained why the drive gear information is not required (still have not). Every single thread, article, website I have found states that the drive gear teeth information is required and every single formula I have found needs that information. I specifically asked if that information is standard, with no response.
I appreciate the help, I am not trying to be difficult, but you didn't request any information from me and I am not smart enough to guess.
Bill needs the stock rear axle ratio form the truck the transmission came from. With that the parts book will tell him the number of drive teeth on the output shaft.
The door jamb certification sticker will have this info on it.
Since the trans came from something else and you likely do not have this info. You are going to have to count the number of gear teeth on the output shaft shaft through the speedo gear hole.
Baring that you will have to pull the tail housing.
I just went and looked at that stuff, there are at least 5 different versions of that output shaft used in trucks & vans1980/89.
No idea about sedans, those are different books.
I will wait and see if he will post the pages from the parts book, he can do it lots faster & easier than I can.
Here's a pic of F250/350 with 3.54-1 ratio, the closest there is. The DRIVEN gears are listed, but that's it.
