AC problems
Once I cleaned the condenser out really well as there was trash stuck behind it before the radiator it's been working like a champ. I was concerned I over filled the AC and have not had time yet to go have it evacuated and filled to correct colume by weight but it is working awesome for now. Maybe it was low from the factory.
Try cleaning you condenser . Make sure there is no trash stuck in there by the radiator. If that doesn't work it could be a blend door issue. I've read that if you disconnect your battery and reconnect it and it works great then the actuator may be bad and by undoing the battery you reset the door location and it closes all the way.
There is a blend door relearn I've seen posted I tried that had me pull fuse #46 in the passenger wheel well and a few other things to retrain it. Honestly that worked awesome since I did that a few weeks ago. On a trip today my vent temps was 42. Outside was 95.
The pressures I have now are close to what you are running. There is a forscan program someone here used to find a sensor on the evap was telling the AC to cut out. If your compressor is on and running I'd clean and look for the blend door issue first. Search for the procedure.
https://www.powerstroke.org/forum/6-...1109426?page=1
And for the eatc system if yours is the electronic control. There is a testing protocol.
https://www.ford-trucks.com/forums/1...ide-vents.html
