Oil
Old Sep 22, 2003 | 04:36 PM
garybanjoman's Avatar
garybanjoman
Question Oil
WHAT IS THE BEST OIL FOR A DEISEL, I'M COMING UP FOR AN CHANGE, AND SINCE BEING A NEWBY, I DON'T KNOW, I WILL BE USING WIX FILTERS.
__________________________________
93 F-250 7.3
Old Sep 22, 2003 | 10:38 PM
dieselzen's Avatar
dieselzen
Oil
I don't know how much of a diesel newbie you are.
The most basic is to look for a diesel rated oil which has the API service ratings: CH-4, CI- 4 and SJ, SL. It must be rated at least CH-4 and SJ combined (these are the next to last API standards).
When I bought my vehicle used, I decided that if the previous owner's brand had gotten it 180,000 miles, it was good enough to stay with. R.A.
Old Sep 23, 2003 | 04:41 AM
nogo73's Avatar
nogo73
Oil
First off let me say welcome to the wonderful world of diesel
Rotella T 15-40 Is all I have ever used (I change my oil every 4000 miles and fuel filter)
also here are some other things to note
1). get fleetgaurd test strips and test you dca
you need to keep up with the coolant additive
2). service your crankcase depression regulator valve (recomended every 6000 miles) this will keep your head gaskets from blowing. you can tell if it needs servicing if there is oil on your air filter retaining bolt
3). don't buy fuel from a station if the tanker is their wait 8 hours after it stoped by buy fuel from a place that has a alot of trucks going through it chances are it will be good clean fuel don't buy when it raining wait a day or 2 after. I also use howes every 1000 miles to clean the fuel system lubercate the pump.
4). Only buy motorcraft glow plugs everything else is junk
( you dont want a tip break off in to the combustion chamber)
That should keep you out of trouble
Old Sep 23, 2003 | 11:22 AM
HrlyDr's Avatar
HrlyDr
Oil
Ok, this CDR valve is new to me...
Where can I find it? I have the banks kit, so obviously I don't have the OEM air cleaner...
Old Sep 23, 2003 | 12:56 PM
nogo73's Avatar
nogo73
Oil
its on the back side of the intake
Old Sep 23, 2003 | 01:30 PM
garybanjoman
Thumbs up Oil
Thanks for the help , i'm sure all this info will come in real handy.
Old Sep 23, 2003 | 02:06 PM
HrlyDr's Avatar
HrlyDr
Oil
Cool. I'm playing heavy mechanic tonight on a buddy's Mack, and then we gotta look at his F-SuperDuty w/ a coolant leak. I'm gonna find this CDR thing and check it out.
Thanks!
Old Sep 23, 2003 | 04:28 PM
dieselzen's Avatar
dieselzen
Oil
Yeah, if the CDR (Crankcase Depression Relief) Valve has gummed up, it will cause oil to leak past the rear crankshaft oil seal.
I was told the seal would never hold again after having oil leak past it. Cleaned the CDR ( do it now every other oil change) and my rear seal leak stopped leaking.
The CDR is located between the Glowplug controller and the Intake. It is mounted in a rubber bushing going to the crankcase and is bolted to a rubber bushing at the intake. R.A.
Old Sep 23, 2003 | 09:24 PM
dieselzen's Avatar
dieselzen
Oil
garybanjoman,
You might be interested in this:
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Some interesting data. R.A.
Old Sep 24, 2003 | 02:54 PM
garybanjoman
Oil
Thanks,the web site was informative, but i've been using WIX
for over 24 years, and employed there for the same length of
time, never had any problems
Old Sep 25, 2003 | 02:44 PM
jayf63's Avatar
jayf63
What do you clean it with?
Old Sep 25, 2003 | 03:23 PM
dieselzen's Avatar
dieselzen
I just remove the CDR from the engine and soak it in gasoline, then brush it with a tooth brush everywhere I can get to and make sure the spring plate isn't stuck to the outside of the valve. I let the gasoline evaporate completely before re-installing. R.A.
Ed
Oil & Lubrication
33
Jan 3, 2006 08:17 PM
hotbbb
Oil & Lubrication
Apr 5, 2005 01:03 AM
snowmonkey
Jun 29, 2004 01:46 PM
