Wix oil filter?
Old Jun 27, 2004 | 05:24 PM
snowmonkey's Avatar
snowmonkey
Wix oil filter?
I am using a Wix oil filter (only one the parts store had in stock. I think wix and motorcraft are the only two available at htis time? Is this correct? I paid $22. Is this reasonable?
Old Jun 27, 2004 | 08:43 PM
SBV45's Avatar
SBV45
A little high. Should be able to find the Motorcraft at about $20. That is what I paid for it at Autozone. You can get them for less on the net.
Old Jun 28, 2004 | 12:37 AM
TXBDBY's Avatar
TXBDBY
Oil Filters
I went straight to the International House and bought filters from them for 17.00 a piece. Not bad for Anchorage, Alaska.
04, 6.0l SRW, F-350 Lariat crew cab and lovin' it
Old Jun 28, 2004 | 05:40 AM
SAYERS's Avatar
SAYERS
I Was Told By The Service Manager That Wix Makes Just About All Of Ford's Filters, I Think That Is A Good Price.
Old Jun 28, 2004 | 06:22 AM
purplewg's Avatar
purplewg
The NAPA guy told me WIX makes their oil filters. I just picked up two for $22 each. I also got my Blackstone sample kit so I'm ready to go. I will continue to use Rotella just like I did in my last PS.
Old Jun 28, 2004 | 09:15 AM
oldfart60's Avatar
oldfart60
Smile Good Source for WIX Oil Filters
I just ordered filters from www.filter1.com. If you order any mix of filters that add up to six the shipping is free. I paid $11.68 for the oil filter and $38 for the fuel filter set. They are Wix filters, and are one of the top rated filters. Wix also makes NAPA's filters. In my opinion with all the vehicles most of us own ordering six filters at a time is easy to do. Hope this helps.
Old Jun 28, 2004 | 09:26 AM
jimmy-six's Avatar
jimmy-six
Oldfart60. Somewhere on this site I read not to use the Wix fuel filters..I also believe someone stated that Ford had a bulletin on NOT using them. I like Wix in all my cars and bikes too. Anyone remembering this should comment...Thanks
Old Jun 28, 2004 | 02:17 PM
oldfart60's Avatar
oldfart60
Wix Filters and FORD
I saw some research that had been done on many different brands of oil filters, where they actually cut them open and compared the media and the bypass mechanisms, and WIX rated very high. I don't believe FORD can tell you what oil and filter you are to use as long as the oil specs are correct for the application and you use the correct filter. That is assuming that you follow the oil change interval correctly.
Old Jun 28, 2004 | 05:01 PM
jimmy-six's Avatar
jimmy-six
60---This is for the FUEL filter only. I have bought and used Wix for the oil and the #'s are exact and both are from Germany. I don't have enough miles yet for the fuel and I read in this site about there use.
Old Jun 28, 2004 | 09:47 PM
PSD6litre40's Avatar
PSD6litre40
the infor stated are pertaining to the 7.3L Fuel FIleter made by wix. Does not pertain to the 6.0L...........
Old Jun 29, 2004 | 08:02 AM
Hjudge49's Avatar
Hjudge49
I orderd a six pack of oil filters from Oilguard, great price, racor filters. Got a 3 pack of fuel filters too. My oil analysis comes back very clean, good filtration reports.
Old Jun 29, 2004 | 08:34 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
OilGuard now offers an aluminum machined oil filter top........very cool.
Old Jun 29, 2004 | 08:40 AM
Hjudge49's Avatar
Hjudge49
I'nm glad you mentioned that. I ordered a new HMFC cap at the dealer a while ago and forgot to go get it. Mine trie4d to crossthread the last time I changed fuel filters, and I had to remove the entire moduel to get it back on straight. That was a major pain. If you have to do it, get the seal kit FIRST! All the lines run into a manifold on the side which is easily remove with 4 small bolts, BUT the gasket/seal of the manifold is like a rubber ladder looking thing and "grows'. Cannot be reused, and will leak if not replaced properly.
Old Jun 29, 2004 | 09:41 AM
SBV45's Avatar
SBV45
Yes, changing the HFCM fuel filter is a major PITA especially with 4x4. Isn't it the same cap as the oil filter?
Old Jun 29, 2004 | 09:44 AM
Hjudge49's Avatar
Hjudge49
I don't think so, but I never compared them side by side. But I know that plastic thing will certainly cross
