Interior color not the same as exterior
I was going to touch up my steering column and ordered some Caribbean Turquoise touch up pant. It matches the exterior quite well. Unfortunately I didn't realize the steering column is quite a bit darker. The steering column perfectly matches the SMS auto reproduction seat cover, so it appears to be the original darker green/turquoise not Caribbean Turquouise. My question is: What color green is this so I can try to find a color match?
This is always an interesting topic. For 1965 and 1966 Custom Cab F100/F250 2WD and 1966 F100 4WD they painted the column, flange, bowl and steering wheel to match the seat upholstery.
My Sauterne Gold (car color) and Wimbledon White tu-tone paint had a column, flange, bowl and steering wheel painted the standard Sahara Beige, which goes good with the Parchment seats and console lid.
Chad
Chad
This is always an interesting topic. For 1965 and 1966 Custom Cab F100/F250 2WD and F100 4WD they painted the column, flange, bowl and steering wheel to match the seat upholstery.
Chad
Chad
I tried doing a search on "interior colors" and it pulled up several threads, but I wasn't able to find the information I was looking for. Sometimes you just have to ask for help. I ordered a rattle can from Express Paint. It has to be custom mixed so it will be at least a week before it delivers. Excellent information Chad!
Chad
Chad
Chad
Chad
My 65 F100 4x was Springtime Yellow. Dash and column was what I assumed was Wimbledon White. IS that correct? I plan to repaint it Winboldon white and use 71 Candy Apple Red for the exterior and interior and do the cab roof in Wimbledon white as well. Not factory for 65 4x4 but think it will look good.
Otherwise, Wimbledon White on a portion of the dash would be correct on Custom Cab (two-tone instrument panel).
One correction to what that says, however, no horn rings on 1965 F100/250 4WD and 1966 F250 4WD.
Chad
Raven Black
Sahara Beige
Marlin Blue
Dynasty Green
Rangoon Red
Wimbledon White
Chad
Chad
I wish I had the same sort of information for 1966 or 1965. This is 1964 and you can see that "B" color code was only available with the Green Vinyl (Standard Cab) or Green Woven Plastic (Custom Cab), excepting the Heavy-Duty Black Vinyl.
If I recall yours was just A7 - two digit DSO - so not a special order - but sounds like a real unique truck.
Chad
Chad
Chad
